586,471 active members*
3,737 visitors online*
Results 1 to 5 of 5
    Feb 2008
    231
    Homing Question
    Wiring up homing sensors to a new breakout board:
    I have 4 separate NPN prox sensors for each axis. A axis is slaved to X axis on the gantry to square it. Can I wire the Z home sensor, then Y home sensor and the X home sensor to 1 input and then wire A sensor to it's own input so that it can find home while X is searching for home at the same time?
    Thanks,
    Scott
    Mar 2010
    621
    I believe the answer to your question is yes as I am currently doing this with a G540 but it may depend on the breakout boards, Gerry seems to be an expert on the subject and hopefully can chime in.
    In my case, X, Y and Z are wired together and A is separate for squaring of the gantry to the table.
    One thing to keep in mind is that you will need some adjustments on the sensors for the X and A axis to square it.
    Adam,
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
    Nov 2009
    4415
    You can wire the switches in any way you like. Generally Mach homes 1 direction at a time unless you change the macro.
    Feb 2008
    231
    Quote Originally Posted by adam_m View Post
    Yes, you were correct. The A axis in our case must be on a separate input so that it can home independently of X. All wired up and working normally now. A sensor is adjustable so that I can square the gantry.
    Thanks,
    Scott
    Mar 2010
    621
    That's great.. glad I was able to help.
    Adam,
  1. Homing Question
    By CanAm1 in forum Mach Mill
    Last Post: 01-16-2011, 10:29 PM
  2. Homing question/setup
    By Regnar in forum LinuxCNC (formerly EMC2)
    Last Post: 05-22-2010, 10:06 AM
  3. Series I Homing Question
    By ranchak in forum Bridgeport / Hardinge Mills
    Last Post: 12-19-2009, 12:20 AM
  4. Homing question
    By IQChallenged in forum Machines running Mach Software
    Last Post: 06-23-2007, 12:29 AM
  5. Homing question
    By Greolt in forum Mach Mill
    Last Post: 08-26-2006, 03:45 PM
