586,119 active members*
3,661 visitors online*
Thread: g43 usbcnc
    Feb 2014
    g43 usbcnc
    Ive used a mach3 post processor someone made for solidworks to create a semi working g code for usbcnc but if i leave it as it is it holds on this line:
    G43 H1 D31 G0 X815.051 Y505.315 Z50. S1000 M3
    with this comment
    L14: D word with no g41 or g42
    now after searching i found that g43 does not like H and D and prefers I and K but then i get
    I word with no g2 or g3 or g42.1 to use it
    the thing is if i take the line out completely he takes the code, but makes a collision (seemingly in mid air)
    L69: MCA
    i have been at this for 3 days now and am on the verge of crying, since it seems i made promises that i cannot keep
    but boys dont cry! (they drink heavily instead)
    help pls...
    Try using G43 H1 by itself. You should probably have that broken into 3 separate lines
    G43 H1
    S1000 M3
    G43 normally uses H to specify the tool # for the offset
    G41/G42 normally use D for the Tool # for the offset.
    I and K are used with G2/G3
    Feb 2014
    thank you,
    it went further but sadly halted on the second tool with the following:
    G43 H2
    G0 X393.733 Y78.127 Z100.
    S1000 M3
    L69: MCA Collision
    Oct 2013
    153
    You should use this way
    G0 X393.733 Y78.127 S1000 M3
    G43 H2 Z100.
    Using XYZ axises together in the first line will definitely result in collision
    Feb 2014
    thank you!
  1. What Postprocessor to use with USBCNC
    By Peter Nielsen in forum Dolphin CAD/CAM
    Last Post: 01-12-2016, 07:49 PM
  2. Eding USBCNC
    By Web Goblin in forum EdingCNC
    Last Post: 05-29-2014, 09:11 PM
  3. USBCNC Umbau
    By broken tool in forum Controller Cards
    Last Post: 03-28-2013, 01:10 PM
  4. USBCNC CPU V4
    By Web Goblin in forum Controller Cards
    Last Post: 05-23-2012, 05:23 PM
  5. almotion usbcnc
    By the evil E in forum Haas Mills
    Last Post: 11-24-2010, 11:40 PM
