HP requirements for spindle motor question
I am having a difficult time deciding where to post this question on the forums, I highly doubt this is the best spot but after ten minutes of looking I figured I should just post my question and if I need to move it, I'll do so.
I need to figure out a way to calculate how much HP (watts, whatever) I'll need for my spindle motor for a small machine I am finishing up. Currently I am running either a 3hp knee mill CNC to cut these parts or my 24hp VMC. It doesn't register virtually any load at all on the VMC and the kneemill seems to be under no strain either. I will be cutting the exact same thing over and over and over for literally millions of inches and I do not want my larger pieces of equipment tied up on these parts.
I am using a .250" 4 flute carbide cutter .220 deep in 410 and 420 stainless. It will be cutting full width with probably a 0.003" per tooth per revolution chip load or less. (I need to be careful going much less or the material work hardens and breaks the cutter.) I'll be running between 1,000 and 1,200 rpm since the cutters last the longest in that range. It will have coolant and the cutter is cutting completely through a plate. It will be piercing through holes that have already been predrilled so the ONLY thing I'm trying to figure out is what would be the easiest way to calculate my power requirements for the spindle motor if I were to operate at around 16 hours a day? I don't need to cut these parts particularly fast, I need them to run consistently unattended while I'm not right there, so speed isn't as important as cutting reliable.
Unfortunately I know very little when it comes to electric motors so I think my questions would be (and forgive me if I word this wrong):
-How many watts would I need to cut this material or what would be the best method to calculate and/or measure this?
-Say it needs 750 watts minimum, (I have no idea,) would I look for something with 50% more peak power than this? 75% more? 250% more?
-How do I figure out peak power verses the power it can pull 30 minutes to "infinity" at a time?
-I need to run this on single phase because I will not have access to the 3 phase power in my shop for this application, does this matter?
-Is there any benefit to running a cooling jacket around the motor to pull away excess heat buildup for extended run times?
-What benefits would gearing down a higher RPM motor to my 1,000 to 1,200 rpm's give if any?
Thanks in advance, I know what I'm trying to ask but I'm just not sure I know how to word it!
EXIT 85 Manufacturing "The best custom wheels, period" (www.exit85.com)
Experts in low volume, highly complicated, one-off forged aluminum wheels
