586,111 active members*
3,522 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Corner Radius Endmill add strength to part?
Results 1 to 5 of 5
    Sep 2010
    81
    I've heard that a corner radius endmill will add strength to your parts when doing things like making pockets in aluminum
    Is it worth almost twice the price for an endmill that does this? I'm sort of torn since the corner radius isn't really optimal helix angle (extra +5 degrees than recommend) and twice the price.
    Apr 2006
    3206
    Is it worth it? It's your call.
    Depends on your design criteria.
    http://www.racer.com.sg/files/33681218772436pdc2.pdf
    down around 13) Corner Radius you'll find some help.
    Jul 2005
    12177
    Having a small radius instead of a sharp corner does not add much strength but it can make an enormous difference to fatigue resistance, especially in the case of aluminum and its alloys which will eventually fail due to fatigue when they experience a reversing or cyclic load.
    Is this applicable to the bottom of pockets? That depends on how the part is stressed. If the part is a load bearing part where the pockets are for the purpose of reducing weight then probably corner radii are a good idea. Actually for some parts they are essential; think 'wing spars' on aircraft.
    Small radii at the bottom of counterbores for bolts are probably a good idea especially if the part is highly stressed in a cyclic manner.
    Radii are also a good idea at any abrupt changes in thickness because a sharp corner here can create a region of raised stress that may exceed the failure strength of the metal under a bending load; even when the average or distributed stress is well below the failure limit. This is a situation where a radius can inprove strength.
    Because it can be slower machining pockets with a corner radius mill you have to use your judgement, or get advice from the designer of the part, as to whether a radius is wise, or essential, in a particular area. Certainly if you are making pockets that form the internal cavities in some sor of high pressure hydraulic or pneumatic manifold radii are probably going to be needed. In this case they should be called out in the drawing or model and omitting them is a bit irresposible.
    Sep 2010
    81
    Quote Originally Posted by Geof View Post
    No pressure chambers here, just a set of dropouts for a high-end downhill mountain bike. You convinced me to give the small radius a try especially since it is a high strength part. I'm going to run two test cuts in my metal tomorrow and see which cuts better. I think the radius also adds a little nice touch aesthetics wise
    Jul 2005
    12177
    ...dropouts for a high-end downhill mountain bike...
    I don't have the faintest idea what a dropout is but In my opinion any part on a mountain bike should get the same thoughts as wing spars. Corners radiused, finishes as impeccable as possible, etc.
  1. corner radius
    By kendo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-05-2010, 08:06 PM
  2. carbide corner rounding endmill
    By samu in forum MetalWork Discussion
    Last Post: 09-19-2009, 02:12 AM
  3. Corner Radius Tools?
    By machred23 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-18-2009, 05:09 AM
  4. Radius on the corner of square stock
    By ErnieD in forum MetalWork Discussion
    Last Post: 03-31-2008, 03:35 AM
  5. How to put a radius on the outside corner of a square?
    By Xterrian in forum G-Code Programing
    Last Post: 10-13-2005, 02:21 PM
