586,635 active members*
3,564 visitors online*
    Apr 2013
    31
    Fanuc O-T Control
    I'm sure this has been discussed at some point, but which parameter do I change to get the parts counter to just count the number of pieces I am machining without having to put in a count-up or down number. I just want to display each part as it is finished.
    Thanks in advance,
    Jim
    Mar 2012
    45
    Check parameter 907 bit 4
    Apr 2013
    31
    Thanks for the reply,
    907 parameter is 01011010
    Jim
    Jan 2013
    7
    Option bit is already set.
    So please check parameter
    40#3 normally 0
    219 (normally 30)
    in this case M02 or M30 will increas the counter.
    If parameter 219 is set 87 (example) then use M87 for counter
  1. Replies: 5
    Last Post: 05-31-2019, 05:16 PM
  2. Replies: 7
    Last Post: 11-17-2013, 01:46 AM
  3. Fanuc 18i-TB Control
    By bandy in forum Fanuc
    Last Post: 10-22-2010, 05:27 PM
  4. FANUC O CONTROL
    By gabedrummin in forum Fanuc
    Last Post: 06-07-2009, 08:32 AM
  5. fanuc 0tf control
    By gcrandall in forum Fanuc
    Last Post: 09-03-2006, 07:55 AM
