I was about 20 min into a cut and mach just stops. There are no limit switches to trigger and no response using the keyboard to moves an axis.
It also happened while mach 3 was idle (hobbycnc board powered on) and I stepped away from the computer for 90 minutes. When I returned
again no axis response. I restarted mach and everything worked fine.
Anyone have a solution to this issue?
Will increasing the debounce help?
Jason
