586,113 active members*
3,146 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan Lynx 220 LM M35 Not Working--Help Needed
    Feb 2011
    80
    Ok, so Saturday morning and have a problem on Doosan Lynx 220LM. When control gets to M35 to activate C axis nothing happens. The green cycle start light stays lit and machine just sits there. It is not a new program at all, rather a program we run once a month all year long. Also in jog mode I cannot rotate the C axis with the handwheel. I have a FIN at the bottom of the screen which means it is not finishing the M35. Any ideas? Thanks!
    Jun 2003
    11
    I seem to be suffering the same problem on a Puma 2100sy w/ 31i control. Did you ever figure this issue out?
    Mar 2014
    11
    Re: Doosan Lynx 220 LM M35 Not Working--Help Needed
    Does the c axis lock(break on)? Does the machine position on C read zero when referenced? And if you use a G76 threading cycle in turning mode(m34) does it work? Had similar problem on puma 280m?
  1. Doosan Lynx 220LC manual needed...
    By Steve_W in forum Daewoo/Doosan
    Last Post: 02-10-2017, 05:58 PM
  2. lynx doosan 220
    By tpsimer in forum MetalWork Discussion
    Last Post: 02-08-2014, 06:27 PM
  3. Doosan lynx 220lm
    By mattlynx in forum Uncategorised MetalWorking Machines
    Last Post: 02-02-2014, 11:11 PM
  4. Just bought a doosan lynx 220
    By elementmachine in forum CNC Wood Router Project Log
    Last Post: 09-11-2013, 10:00 PM
  5. Doosan Lynx 220
    By Schljuutene in forum Daewoo/Doosan
    Last Post: 02-12-2010, 06:44 AM
