586,329 active members*
4,952 visitors online*
Results 1 to 12 of 12
    Oct 2003
    67
    CNC Vinyl cutting
    I used to operate plotters at the sign shop I worked at long ago. I'd use Casmate and Graphicad back in the day. Anyway, the plotters used spring loaded adjustable swivel knives. The plotters overcut adjoining lines to account for the blade width so the cuts were connected.
    I was wondering if anyone has tried cutting vinyl this way with their home made CNC machine and if they've had to account for this in their G code.
    How did the vinyl turn out? How small can you go with fonts?
    Darren
    Sep 2003
    1469
    Here's a link of a vinyl cutter.
    http://www.cuttingedgecnc.com/vinyl.htm
    Hager
    Apr 2008
    59
    I have been working on a vinyl cutter tool. I did a bit of testing on Friday and after a couple of false starts I think its ready:
    [nomedia="http://www.youtube.com/watch?v=GcJB2Bf4Qyc"]YouTube - Vinyl-cutting-1.wmv[/nomedia]
    [nomedia="http://www.youtube.com/watch?v=8nUfqMjmRvE"]YouTube - Vinyl-cutting-2.wmv[/nomedia]
    Not sure about small fonts but it did manage the antennae on a butterfly sticker. The antennae are about 2 inches long but maybe a 32nd wide at the slimmest. That bodes quite well for small fonts.
    Bob
    Apr 2005
    253
    I seen these holders on Ebay so would make implementing on a cnc router easy enough I think
    I'll get it finished sometime after I start it.....
    Apr 2009
    5516
    Quote Originally Posted by Darren_T View Post
    Darren
    LOL I STILL work with CasMate! And I still find it easier than anything I ever used. Surprisingly it runs in Windows 7, not bad for 20 year old software!
    Dec 2010
    337
    i bought this vinyl cutting head about 3 years ago, It's made by Roland.
    The 'blades' are held in place with a tiny bearing ring and spring mounted. Height is adjustable by the brass ring on the outside.
    I'd tried some cheaper ones off ebay but this worked a lot better but was a bit more expensive.
    It didnt come with the jubilee clip(probably obviously) or the metal its attached to;a friend made made that, but the assembly worked well to.
    The cnc i had at the time was a tiny kit job and the stepper drivers didnt allow for curves, so everything i cut was made up of straight lines, BUT, it was able to cut fairly quickly very thin parallel lines: with the right vinyl, 1mm apart or maybe less, i didnt measure.
    It depends a lot on what youre cutting. I generalyl didnt cut to small cause it took to long to weed it *
    I was going to hook this up in the week but havent got around to it what with work and that, got rolls of vinyl lying about, will post a few vids of it cutting curves if its of interest.
    Attached Thumbnails Attached Thumbnails photo0609.jpg   Photo0610.jpg   Photo0611.jpg   Photo0612.jpg
    Apr 2008
    59
    Neurofen,
    How much was the Roland cutting head?
    Cheers,
    Bob.
    Oct 2010
    65
    These guy's make a cutter for your CNC
    cnc 1/4" knife holder
    Dec 2010
    337
    Quote Originally Posted by Bob Shaw View Post
    Neurofen,
    Cheers,
    Bob.
    approx. £40 including delivery and 5 blades.
    Apr 2008
    59
    I'm selling my cutter on Ebay
    CNC Vinyl cutting tool. Ideal for signs and lettering. on eBay (end time 09-Mar-11 12:47:47 GMT)
    Roland blade, 10mm or 1/2" shank. Twin bearing, all stainless construction. Lifetime guarantee. Free worldwide postage.
    £48 on Ebay but I guess I'd sell one to anyone here direct for £40 ($70). Just PM me.
    Mar 2015
    6
    Re: CNC Vinyl cutting
    for the laser cutting plotter adopt laser and general cutting plotter advantage. More quicker speed, not only for vinyl stick cutting and paper drawing, Suit more materials, such as stencil, paper, leather, software plastic, textile scroll for laser cutting and engraving.
Name:	Laser cutting plotter.JPG
    Laser Engraving Cutting Plotter Machine Stencil Template Vinyl Cutter ENGRAVER | eBay hope it is useful.
    Nov 2014
    74
    I have cut a lot of vinyl using the widget works cutter works awesome
    https://youtu.be/05-rH2S3YCs
  1. Venture into Vinyl Cutting
    By Starleper1 in forum Benchtop Machines
    Last Post: 12-11-2012, 03:27 PM
  2. Vinyl cutting
    By ssutton in forum DIY CNC Router Table Machines
    Last Post: 12-04-2011, 09:06 PM
  3. vinyl cutting head
    Last Post: 11-10-2011, 12:53 PM
  4. Any Tips on cutting Vinyl
    By rxrotary2_7 in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 05-13-2005, 03:46 PM
  5. Vinyl Record Cutting
    By Hasher in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 01-10-2005, 11:54 AM
