587,058 active members*
4,116 visitors online*
    Oct 2013
    AXYZ 4008 ATC Scenic Carpentry
    Hello,
    Just used this machine to run a template for a curved stair case for the Stratford Festival. I just started a 19' curved crown moulding out of styro.
    Check it out...Attachment 225404
    Apr 2012
    141
    would like to see more pics
    Oct 2013
    Here is a couple of cuts we made on the machine, we used styro to make a crown moulding for a curved wall.Attachment 227604Attachment 227606 and here is the wall.Attachment 227608
    The upper and lower curve is cut on the CNC and I framed it 16 on Center, it's about 3ft tall.
    Oct 2013
    Attachment 228498
    I flipped unit upside down and started with the "dental" I used PL Premium and screws. I built each layer staggering the seems on each layer.
    Attachment 228500
    As each layer grows, I can only screw into the top plate (now on bottom) the foam is dense enough to screw into and hold the layer to let the glue dry.
    Attachment 228502
    Apr 2012
    141
    Re: AXYZ 4008 ATC Scenic Carpentry
    Progress please :-)
  1. axyz
    By DeCosse in forum Commercial CNC Wood Routers
    Last Post: 04-28-2015, 05:13 PM
  2. AXYZ 4008 CNC Router !!!
    By kawman in forum BobCad-Cam
    Last Post: 08-01-2013, 01:26 AM
  3. Help carpentry!?
    By bichodamadeira in forum WoodWorking Topics
    Last Post: 01-30-2012, 08:11 PM
  4. Axyz Automation 4008
    By Fran_k in forum Commercial CNC Wood Routers
    Last Post: 10-07-2010, 07:22 PM
  5. Why is the cutting bit taking the "scenic tour"?
    By BrassBuilder in forum Dolphin CAD/CAM
    Last Post: 03-18-2008, 03:58 AM
