586,082 active members*
3,613 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Need help creating a correct toolpath
Results 1 to 11 of 11
    Jan 2014
    14
    Hi there. Every time I try to create a rough or finish cycle along the contour of this part, the program skips all the contour passes and just turns the OD. The angle i'm cutting is 30 degrees and I'm using a .031 degree nose radius, so I can't make the finish pass with this tool, but it should still rough it out to the best of its ability, right? pic related, the part i'm making
    Sep 2013
    131
    Are you leaving at least .01 thou on the walls to rough it out?.
    Jan 2014
    14
    Quote Originally Posted by poolrod2 View Post
    are you talking about the stock setup or the roughout parameters? yes to roughout parameters, haven't set up the stock
    Jan 2014
    14
    i mean i can make the program run point-to-point but it doesn't cut out an angle like i need it to. please help
    Jan 2014
    14
    plunge turning at least hits the contour, but it's not cutting the direction it ought to. I just want it to cut negatively in one pass per cycle
    Sep 2013
    131
    I'm not a lathe guy, so I'm not used to the tool paths there. A 3 4 or 5 axis mill would be easy for me, you could rough it out leaving .01 thou in the cut parameters on the walls, and 3d contour or flowline the angle.
    Aug 2007
    If you attach the file Ill look at it
    Jul 2003
    263
    your roughing depth cut may be larger than the contour step that is why it is by passing the feature
    If you can ENVISION it I can make it
    Dec 2008
    3109
    You need to set the "Plunge Parameters" to allow undercuts, either along the turned diameter, or into a face, or both
    - it is under the "lead in/out" button
    At the moment, it is set to assume that the undercut would be done by another operation ( & possibly a different tool shape )
    Apr 2005
    53
    I honestly can not see how you can make this part on the lathe. Forgive my ignorance if I am not seeing what you are trying to do. Shouldn''t you be in a different plane? I always program lathe stuff in G18. Go down to the bottom right and click on planes --> lathe --> D+ Z+ . Then redraw and path your part. The part has to be oriented differenly. Sorry can't help more right now.
    Dec 2008
    3109
    Quote Originally Posted by utengineer04 View Post
    Yes, G18 is a NC code command, usually output by the post processor. The post can have the ability to use TOP & still output turning code
    He has already got a path on the screen, by using a 35° tool
    -- his problem is..... the roughing op is not putting paths in the wide groove on the outer diameter
    As I said, he has to alter his "plunge parameters" for that particular op
  1. Replies: 14
    Last Post: 02-28-2012, 03:59 AM
  2. creating toolpath for a simple impella
    By mortzs in forum Mastercam
    Last Post: 05-07-2010, 11:35 PM
  3. creating a text toolpath
    By dpark1 in forum Mastercam
    Last Post: 08-27-2007, 04:58 AM
  4. creating toolpath mastercamx
    By tangent in forum Mastercam
    Last Post: 03-25-2007, 04:55 PM
  5. Toolpath correct?
    By cncrunner in forum GibbsCAM
    Last Post: 04-02-2004, 06:50 AM
