good day
I have a problem with my machine and need some help, i put some pictures with the error codes if anyone know´s what is the problem!!!!
Attachment 225430
Attachment 225432
Attachment 225436
good day
Attachment 225430
Attachment 225432
Attachment 225436
Looks like a contractor or I/O point for the tool changer may have an issue. Have you check the wiring, contactors, relays?
Sent from my iPad using Tapatalk
You need to go to mech jog and press drum to spindle and drum to park. If the red led comes on under the button then the switches are working. If the red led does not come on then the switch is not working and may need to be adjusted. You can also look at the program ware under more, service, program ware, display, I/O board and see all the inputs and outputs in real time. I is for inputs and O is for outputs. Mike cncmachineservices (dot) com
