586,058 active members*
4,263 visitors online*
Results 1 to 8 of 8
    Jul 2003
    96
    high speed maching h13
    Anyone have any experence using 2 flt carbide flat bottom endmills for cutting pockets in h13 steel? And what speeds and feed do you use?
    499
    What brand tool is it?
    I would'nt think a two flt would have the geometry your
    looking for to machine H13.
    Is it coated? Is it heat treated?
    All important variables.
    PEACE
    Jul 2003
    96
    Actually I was using a cleveland 2flt coated ticn witha high helix to mill deep pocket up to 2" deep running a .050 ramp, 55ipm witha 7850rpm and it worked quuite well. When the tip would start to get dull the operator would touch it up on the grinder and keep going. Worked quite well. Then they discontinued the tool. Murphys law. Get one that works and poof. Now I'm looking for a replacement.
    499
    I'll look tommorrow and see if I can find you anything.
    Is your material heat treated?
    PEACE
    Jul 2003
    96
    no, not heat treated just gummy h13. I realize most people don't run them like this, but it worked really well.
    Oct 2003
    86
    See: http://members.cox.net/camminc/MetalMAX Stability Chart H13.pdf
    Jul 2003
    96
    The link doesn't take me there?
    Oct 2003
    86
    Sorry, I messed up.
    Go to http://members.cox.net/camminc/
    Go to Chart H13 on that site.
  1. High Speed Spreadsheet
    By MachineSMM in forum Hard / High Speed Machining
    Last Post: 05-21-2014, 01:57 AM
  2. What is high speed machining
    By Klox in forum Hard / High Speed Machining
    Last Post: 04-11-2014, 05:13 AM
  3. High Speed Hard Milling
    Last Post: 03-28-2006, 01:31 AM
  4. High speed rotary coolant coupling
    By CAMME in forum Mechanical Calculations/Engineering Design
    Last Post: 02-22-2005, 03:14 AM
  5. high speed rotary table?
    By jleiwig in forum Benchtop Machines
    Last Post: 11-18-2004, 04:39 AM
