586,533 active members*
2,823 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > does deskproto do 2d and 2.5d very well?
    Oct 2007
    446
    Question does deskproto do 2d and 2.5d very well?
    I couldn't find any examples on the website.
    Would like a reasonably priced cam that supports 4th axis machining...which it looks like it does, but what about 2d and 2.5d jobs?
    Simply importing a vector file and setting pararmeters...?
    Feb 2010
    62
    DeskProto can indeed do 2D CAM: in a 2D operation you can import a 2D DXF file, the cutter will follow the lines in that drawing. In the 2D operation parameters you can set the cutting depth. For a rotation axis job the 2D drawing will be wrapped around the cylinder shaped stock.
    I need to mention though that the functionality for 2D is (by far) not as complete as for 3D.
    To test this you can use the wizard "Basic 2D machining" in the trial version, and for more information you can read the lesson on 2D machining in the Tutorial book. Both are downloads on the DeskProto website.
    Lex.
  1. helloWorld . deskProto + BIESSE .
    By Inigo Montoya in forum Uncategorised CAM Discussion
    Last Post: 11-16-2013, 09:00 PM
  2. Deskproto - How to cut it out?
    By dan j in forum Uncategorised CAM Discussion
    Last Post: 10-19-2012, 09:24 AM
  3. Any reccomendations on DeskProto?
    By darinmurray in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-09-2010, 04:29 PM
  4. MeshCAM vs. Deskproto
    By CuttersCov in forum Uncategorised CAM Discussion
    Last Post: 03-14-2009, 12:33 AM
  5. Deskproto 4 Full pricing?
    By saturnnights in forum Uncategorised CAM Discussion
    Last Post: 03-08-2006, 07:15 PM
