586,094 active members*
3,993 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > How to drip feed a Fadal (4020 or 3015) ?
Results 1 to 10 of 10
    Mar 2007
    304
    Hi Group,
    - A machine shop owner buddy of mine just had one of his key employees pass away - that operates his 4020 and his 3015 Fadals.
    - Apparently, the operator was drip feeding the Fadal's from a laptop (he's still investigating what software he was using on the laptop/PC).
    - Can anyone direct me to a Fadal user manual on how to set the Fadal up into a Drip Feed Mode? (specifically how do you set the baud rate, how do you get it into a mode where it will receive blocks from the PC ? What do you type in?).
    - The cables and programs are still there, just need to know the Fadal commands.
    - As soon as I know what drip feed software he was using - I'll post that info, too.
    Thanks For the Help!
    Joe
    www.CNC-Joe.com
    CNC Is Not Just My Passion.. It's My Addiction !!!!
    Mar 2008
    683
    Sorry to hear for your loss.
    The fadal is very easy actually.
    I don't know what vintage your machine is but the DNC and load program is in the "memory" command. You can "memory" "input" or DNC and it's is fairly straight forward.
    Here's a link for online manuals. If you PM me I can go step by step and keep notes. It is such automatic habit for me I forget what I push to load a program or drip feed.
    Flint Machine Tools, Inc.
    156
    You can use a FADAL program called ASSIST, select PROGRAMs, and from the list, 10. VMC DNC. The program should not end with a M2. The last line of the program should be M0.
    Safety - Quality - Production.
    Jan 2004
    3154
    NCFadal is excellent for the older machines. My runs always end in M2, I only use M0 for a stop-break in the middle of a cycle when required
    www.integratedmechanical.ca
    156
    Quote Originally Posted by DareBee View Post
    I am unable to get that newer version of NCfadal to work on my xp machine. The older version is ran in Windows 98.
    The M2 returns the control to what is in memory.
    Apr 2013
    99
    easiest way is to get the usb adapter from calmotion then just load the program on a usb stick and
    use the dnc command on that, no more laptop evolved
    Apr 2006
    3206
    Quote Originally Posted by LSM View Post
    Installing the Calmotion USB adaptor was the best thing I ever did on the 4020.
    Jun 2012
    516
    Re: How to drip feed a Fadal (4020 or 3015) ?
    Quote Originally Posted by Paul_S View Post
    I run my fadal using NCFadal that is on a small Dell computer that's bolted to the control cabinet. no monitor or keyboard. I then remote desktop into that pc, and use NCFadal over remote desktop. Once you start the program on NCFadal, the control will say 'waiting...' then you press cycle start and you're off!
    my shop computers run windows 7 and windows 8 so I doubt it's an xp compatibility thing. maybe a port settings thing?
    granted, I have an older machine. 1992 4020 w/cnc88 (1400-4 processor)
    180
    Quote Originally Posted by fizzissist View Post
    What do you like about it?
    I'm actually interested in getting one but there were a couple of things that I was thinking I wouldn't like too much like having to sneakernet the USB key back and forth to the office and being limited to 8 digit file names.
    Jan 2009
    107
    I thought about going the calmotion route, but ended up going with this:
    Moxa Wireless Device Servers NPort W2150A/2250A - 1 and 2-port RS-232/422/485 Wireless Device Servers
    Nice thing is everything gets sent directly from the machine that does the cad/cam. No noise - no issues. You can run it as fast as your Fadal will allow. I have a short 1' cable from the wireless rs232 box to the fadal.
    Works incredibly well.
  1. Drip feed DNC
    By forhire in forum NCPlot G-Code editor / backplotter
    Last Post: 07-09-2011, 04:59 PM
  2. I-80 drip feed
    By ka67_72 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-18-2010, 12:28 AM
  3. drip feed
    By kirby in forum Fanuc
    Last Post: 11-29-2009, 03:04 AM
  4. Drip Feed
    Last Post: 10-20-2008, 03:21 PM
  5. Replies: 17
    Last Post: 11-15-2004, 11:58 AM
