586,409 active members*
3,127 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma lb15 II-m OSP7000 IGF
    Feb 2014
    Hello dos somone now if its posible to out put x and y coordinate from IGF.
    Feb 2009
    6028
    If the machine has a Y axis...
    Not sure of your question. IGF posts to G-code, doesn't run programs in IGF graphic mode.
    Apr 2009
    1262
    If you are milling and working on the face of a part it is possible with G137 mode to get X-Y coordinates output to your G-code. Otherwise Y-axis machine is needed to get Y-coordinates.
    Best regards,
    Feb 2014
    When i draw programs in igf I use x any y
    but when u out put program its in x and c
    x and c are more difficult to change.
    Apr 2009
    1262
    If I remember right, there is an IGF parameter that lets you select X-C OR X-Y output. Dig through those on your machine to see if it's in there.
  1. OKUMA OSP7000 reload datas procedure
    By asstec-italia in forum Okuma
    Last Post: 02-12-2024, 02:20 AM
  2. OKUMA OSP7000 LATHE
    By cbrannam in forum Post Processors for MC
    Last Post: 02-22-2013, 03:39 AM
  3. okuma LB15 help
    By cbrannam in forum Okuma
    Last Post: 10-09-2011, 12:45 PM
  4. Okuma LB25II OSP7000 Wiring Diagrams
    By chenzen666 in forum Okuma
    Last Post: 08-11-2009, 11:16 PM
