586,103 active members*
3,697 visitors online*
Thread: Need Help
Results 1 to 6 of 6
    Oct 2011
    65
    Question Need Help
    Attachment 226078Hello everyone,
    I have a part which I'm currently running in a Citizen L20VIII. I attached pic as well as program. Want I want to learn is how to use main tools while part is in sub. I want to deburr milled flats after cutoff using tool 9. I also attached a clip I found on youtube show what I want to do right after cutoff. I'm thinking i can add a k2 argument to my tool call. But I'm not sure where to place it in program so that it follows cutoff;
    Thanks Attachment 226078 Attachment 226080
    O111255(1-11255 )
    $1
    (1-112)
    M9
    G99G97
    G18
    M6
    M52
    M87
    M97
    G113
    G50Z.525
    G0X.85Z-.05
    (.004 TOOL NOSE RAD.)
    T0200
    M3S1=8000
    /B5(HIGH PRESSURE ON)
    G0X.8Z0T02
    G1X-.02F.002
    G0Z-.05
    X.6
    G1Z.162
    X.750,C.01
    W.01
    G0X.85
    Z-.05
    X.4
    G1Z.162
    G0X.85
    Z-.05
    X.2
    G1Z.162
    G0X.85
    Z-.05
    G0X0.
    G1Z0F.001
    X.185,C.01
    Z.164
    X.75,C.01
    W.01
    G0X.85
    /B5(HIGH PRESSURE OFF)
    G97G0Z-.05T0
    M1
    G610
    (# 2 CENTER DRILL)
    T2100
    G97M3S1=8000
    /B10(HIGH PRESSURE ON)
    G99
    G0X0.Z-.05T21
    G1Z.12F.004
    /B10(HIGH PRESSURE OFF)
    G97G0Z-.05T0
    M1
    (2.3 MM NEXUS DRILL)
    T2300
    G97M3S1=8000
    G99
    G0X0.Z-.05T23
    G1Z.345F.004
    G97G0Z-.05G0T0
    M1
    (M2.5 ROLL TAP)
    T2200
    G99G18G0X0.
    M3S1=2300
    G0Z-.05T22
    G84Z.340D1F.01772S2300,R1
    G80
    G0Z-.05
    G97G0T0
    M1
    M141
    G600
    M5(STOP SPINDLE)
    M18C0
    M1
    ( MILLED FLATS)
    T1200(.461 HORN MILL)
    T12
    G98G19
    M59S3=4000
    G50W-0.59(LOAD OFFSETS)
    /B9(HIGH PRESSURE ON)
    (FLAT 1)
    G0C0.
    G0Y1.35
    Z.370
    X.61
    G1Y-1.07F18
    G0X.553
    G1Y1.07F12
    G0Y1.220
    M1
    (FLAT 2)
    G0C180.
    G0X.656
    G1Y-.886F18
    G0X.496
    G1Y1.084
    G0X.386
    G1Y-1.192
    G0X.325
    G1Y1.22F12
    G0X.275
    G1Y-1.192
    G0X.900
    M1
    (FLAT 3)
    G0C90.
    G0X.582
    G1Y.996F18
    G0X.472
    G1Y-1.104F12
    G0X.900
    M1
    (FLAT 4)
    G0C270.
    G0X.582
    G1Y.996F18
    G0X.472
    G1Y-1.104F12
    G0X.9
    Z-.05T0
    /B9(HIGH PRESSURE OFF)
    M1
    (.236 / 6 MM DRILL)
    T0800
    M58S3=2000
    G0C0.
    G98G19
    G0X.85T08
    Z.401
    Y-.236
    G1X-.6F10
    G0X.850T0
    M1
    (.375 C-SINK 90/CHAMFER #1)
    T0900
    M58S3=500
    G98G19
    G0X.900T09
    Z.401
    Y-.236
    G1X.174F6
    G4U0.2
    G0X.900T0
    M1
    (.157 ENDMILL /.2756 C-BORE# 1)
    (ROUGH)
    T0700
    #510=.265
    #511=.1575
    #512=.314
    #513=6
    #514=[[#510-#511]/2]
    M58S3=4000
    /B8(HIGH PRESSURE ON)
    G98G19
    G0C0.
    G0X.900T07
    Z.401
    Y-.236
    X.5
    G1G98X#512F#513
    G3W#514K[#514/2]
    K-#514
    V[#514*2]W-#514K-#514
    V-[#514*2]J-[#514/2]
    (FINISH)
    #500=.2776
    #501=.1575
    #502=.314
    #503=10
    #504=[[#500-#501]/2]
    G1G98X#502F#503
    G3W#504K[#504/2]
    K-#504
    K-#504
    V[#504*2]W-#504K-#504
    V-[#504*2]J-[#504/2]
    /B8(HIGH PRESSURE OFF)
    G0X.9T0
    M1
    (.375 C-SINK 90 DEG. CHAMFER #2)
    (OFFSET # 19)
    T0900
    M58S3=500
    G98G19
    G0C180.
    G0X.85T19
    Z.401
    Y.236
    G1X.174F6
    G4U.2
    G0X.850T0
    M1
    (.157 ENDMILL/.2756 C-BORE #2)
    (OFFSET # 17)
    T0700
    #510=.265
    #511=.1575
    #512=.314
    #513=6
    M58S3=4000
    G98G19
    G0X.900T17
    Z.401
    Y.236
    X.5
    G1G98X#512F#513
    G3W#514K[#514/2]
    K-#514
    (FINISH)
    #500=.2776
    #501=.1575
    #502=.314
    #503=10
    G1G98X#502F#503
    G3W#504K[#504/2]
    K-#504
    K-#504
    G0X.85T0
    M1
    (.375C-SINK 90 DEG./.059X45 DEG.)
    T0900
    M58S3=2000
    G98G19
    G0X.85T29
    G0C-90.
    Y-.7
    X.450
    Z.140
    G1Y.7F10
    X.38
    Y-.7
    G0X.85
    G0Z-.05T0
    M1
    M5(STOP SPINDLE)
    M18C0
    M1
    ( MILLED FLATS)
    T12
    G98G19
    M59S3=5000
    (FLAT 1)
    G0C0.
    G0Y1.35
    Z.370
    X.551
    G1Y-1.1F25.0
    G0Y1.35
    X.9
    M1
    (FLAT 2)
    G0C180.
    G1X.275
    G1Y-1.28
    G0X.900
    M1
    (FLAT 3)
    G0C90.
    G1X.472
    G1Y1.125
    G0X.900
    M1
    (FLAT 4)
    G0C270.
    G1X.472
    G1Y-1.125
    G0X.900
    G50W0.59(CANCEL OFFSETS)
    G99G40G18M60(CANCELMILL)
    G0Z-.05T0
    M1
    (ODTURN DEBURR.004 TOOL NOSE RAD.)
    T0200
    G97M3S1=6000
    G0Z-.05
    X0T02
    G1Z0F.003
    X.1572,C.006F.0005
    Z.165
    X.78
    G0X.85
    G97G0Z-.05T0
    M1
    !L10
    ( CUTOFF)
    N19
    T0100
    /B4
    M87
    M97
    G97M24M3S1=3000S2=3000
    G114.1H1D-2R0.0
    G99G18
    G0Z1.204
    G650(SUPPORT ON)
    !L20
    !L30
    /B4
    G50W-0.625(LOAD OFFSETS)
    /B1(HIGH PRESSURE ON)
    G99
    G0X.900Z.579T01
    G1X-.02F.003
    /B1(HIGH PRESSURE OFF)
    G50W0.625(CANCEL OFFSETS)
    G97
    G113(CANCEL SPIN SYNC)
    M86
    M96
    G600
    M5
    M25
    G4U.5
    M8
    M8
    /M98P8000
    M9
    M9
    M7
    G4U.5
    G0X-.02Z0.525T0
    M6
    M56
    M53
    M118
    G999
    M118
    M5
    N999
    M2
    M99
    $2
    M118
    (SAFE START CODES)
    G99
    G50Q2000S8000
    G50Z0
    (END SAFE START CODES)
    G610
    G600
    T3000
    G4U.5
    G50Z0
    M98H21(ABD-125375R)
    G50Z0
    M98H100(EJECT PART)
    !L10
    M16(SS OPEN)
    M118
    G650(SUPPORT ON)
    M77(WAIT FOR SYNC)
    G0Z-.05
    G98G1Z.125F10.0
    G4U.5
    !L20
    G99
    M15(SS CLOSE)
    !L30
    G600
    G50Z0
    G999
    M52
    M98H21(ABD-125375 R)
    M98H100(EJECT PART)
    M53
    N999
    M2
    M99
    N21(ABD-125375R)
    T3200
    G44G97M24S2=6000
    G50U0.114(LOAD TOOL OFFSET)
    G99G18
    /B4
    G0Z-.05
    X-.700T32
    Z0.
    G1X0.0F.001
    /B4
    G50U-0.114(CANCEL TOOL OFFSET)
    G97G0Z-.05T0M25
    M99
    N100(EJECT PART)
    M25(SS STOP)
    M33
    G0Z1.500
    M16(SUB OPEN)
    M10(KNOCK-OUT ADVANCE)
    G4U2.0
    /B4
    G4U0.5
    /B4
    M11(KNOCK-OUT RETURN)
    T3000
    G50Z0
    M119
    M99
    $0
    A
    #814=0000007500
    #815=0000001000
    #816=0000001000
    #817=0007000000
    #822=0000000030
    #824=-000000200
    #818=0000012820
    #819=0000001000
    #820=0000000000
    #821=0000000520
    #990=0000142000
    #991=0000051000
    #992=0000061000
    #893=0000000000
    #25119=0000012820
    Sep 2011
    261
    I did something similar. I cut a .008 slot in the part from the sub with the gang tools. Once I had a good part in the sub and my endmill in the main, I moved the Gang into position. Then I recorded Z2 at its home position. I hand wheeled the sub up to the endmill and touched it off until I felt a little drag with a shim. I recorded the Z2 number at the face of the endmill and calculated the difference between the 2. This was my G50Z-6.310 shift in the sub program below.
    I cold have done this differently after looking at it again, I didnt need to Z1/Z2 sync, I could have programmed the Z moves in $2 and just had a wait code in $1, but this is how I did it at the time.
    So the main thing you need to do is calculate the G50 from Z2 home to the part shimmed to the tool. Once you have that distance, you can program it semi-regularly
    Main/$1
    IF[#508NE0]GOTO808 (skip mill macro)
    IF[#500NE0]GOTO808 (skip mill if sub work disabled)
    M5
    !2L6 (queue with M98H6 code on sub)
    (MILL .008 SLOT ON SUB)
    T800
    G0Z-.2
    G811
    !2L800 (sub approach)
    M58S3=5000
    G1G98X.05F10.T8 (mill slot)
    G1X.022F5.
    W-.076F1.
    X.04F5.
    G0W.076
    G0X.6M60 (clear)
    !2L802
    G810 (cancel sync)
    !1!2L880
    N808
    SUB
    N6
    (CUT .008 SLOT)
    T3000
    G811 (superimpose)
    M118
    G50Z-6.310 (calculated from Z2 home to part and tool face)
    M48 C0
    G0 Z-.1
    G1 G98 Z-.008 F10. (arbitrary starting point)
    !1L800 (wait for $1 to cut slot)
    !1L802 (done cutting slot)
    G0Z-.1
    G50Z6.310
    U0W0T0
    G810 (sub home)
    G50Z0
    !1!2L880 (done)
    M99
    You probably have it easier if you're only trying to chamfer the back, as it will just be a simple Z move, then Y, with some C indexing possibly.
    CNC Product Manager / Training Consultant
    Apr 2009
    101
    I do this all the time on our A20.
    You shouldn't have to worry about that G50 distance that MCImes talked about if you use the K2 argument.
    I use two G600's to block around that live tool call in $2. I usually put it after a facing pass on the main spindle, retract the main to Z-.050, then call the live tool with K2 from the sub spindle, do the work, then issue another G600 to let the sub go home.
    With K2, the cutoff face of the part is Z0.0 and the centerline of the tool is Z0.0. No G50 like calling the live tools from the main side.
    HTH,
    Dan
    Sep 2011
    261
    Quote Originally Posted by danrudolph View Post
    HTH,
    Dan
    It might be because Im still using WinCNC 2k, but it doesnt show the K2 argument and I'm not familiar with it. Can you explain or paste the explanation of how this is used? I'd like to use this, as we do this semi frequently. Also, do you know when this became an option/argument?
    Apr 2009
    101
    From the text file, which I believe is the one from WinCNC:
    T0100-T900 *(Front side Gang tools)
    T0200 X Y Z Q1 H K2 E
    T700 K2
    X.3 = Use X to position X after the tool call.
    Y.3 = Use Y to position Y after the tool call.
    Z.3 = Use Z to position Z after the tool call.
    Q1 = Quick index. This will not move to safe position then index,
    It will move from where it is to the new tool in a straight line.
    H.5 = Temporary change position point for just this one index.
    K2 = Used to call the Z2 axis as being programmed. If 'T3100K2' in $1
    then X1-Y1-Z2-C2 are programmed in $1. K2 is canceled on any other
    Tool call. Also if using 'T100K2' to 'T600K2' the Z2 zero position is
    automaticaly set to the back side of the tool knowing the sub spindle
    with part face as zero. If 'T700K2' to 'T900K2' is used then the Z2
    zero position is automaticaly set to the center of the live tool
    knowing the sub spindle with part face as zero.
    $1 T0300 $1=X1Y1Z1C1 $2=X2Z2C2
    $1 T0300 K2 $1=X1Y1Z2C2 $2=X2Z1C1
    $2 T0300 alarm -not alowed
    $2 T0300 K2 $1=X2Z1C1 *$2=X1Y1Z2C2
    E90.= Use E to save cycle time. The C axis will go to E90. while changing
    tools. Do not use M5 and do not use M18
    Not sure when this was added and/or to what machines. Like I said, I have this on our A2-20.
    Dan
    Sep 2011
    261
    Thanks for that. That function must have come along after 2005, as thats when our L20's are from and they wont accept the K2 modifier.
    Good to know though. Thanks again
