Attachment 226078Hello everyone,
I have a part which I'm currently running in a Citizen L20VIII. I attached pic as well as program. Want I want to learn is how to use main tools while part is in sub. I want to deburr milled flats after cutoff using tool 9. I also attached a clip I found on youtube show what I want to do right after cutoff. I'm thinking i can add a k2 argument to my tool call. But I'm not sure where to place it in program so that it follows cutoff;
Thanks Attachment 226078 Attachment 226080
O111255(1-11255 )
$1
(1-112)
M9
G99G97
G18
M6
M52
M87
M97
G113
G50Z.525
G0X.85Z-.05
(.004 TOOL NOSE RAD.)
T0200
M3S1=8000
/B5(HIGH PRESSURE ON)
G0X.8Z0T02
G1X-.02F.002
G0Z-.05
X.6
G1Z.162
X.750,C.01
W.01
G0X.85
Z-.05
X.4
G1Z.162
G0X.85
Z-.05
X.2
G1Z.162
G0X.85
Z-.05
G0X0.
G1Z0F.001
X.185,C.01
Z.164
X.75,C.01
W.01
G0X.85
/B5(HIGH PRESSURE OFF)
G97G0Z-.05T0
M1
G610
(# 2 CENTER DRILL)
T2100
G97M3S1=8000
/B10(HIGH PRESSURE ON)
G99
G0X0.Z-.05T21
G1Z.12F.004
/B10(HIGH PRESSURE OFF)
G97G0Z-.05T0
M1
(2.3 MM NEXUS DRILL)
T2300
G97M3S1=8000
G99
G0X0.Z-.05T23
G1Z.345F.004
G97G0Z-.05G0T0
M1
(M2.5 ROLL TAP)
T2200
G99G18G0X0.
M3S1=2300
G0Z-.05T22
G84Z.340D1F.01772S2300,R1
G80
G0Z-.05
G97G0T0
M1
M141
G600
M5(STOP SPINDLE)
M18C0
M1
( MILLED FLATS)
T1200(.461 HORN MILL)
T12
G98G19
M59S3=4000
G50W-0.59(LOAD OFFSETS)
/B9(HIGH PRESSURE ON)
(FLAT 1)
G0C0.
G0Y1.35
Z.370
X.61
G1Y-1.07F18
G0X.553
G1Y1.07F12
G0Y1.220
M1
(FLAT 2)
G0C180.
G0X.656
G1Y-.886F18
G0X.496
G1Y1.084
G0X.386
G1Y-1.192
G0X.325
G1Y1.22F12
G0X.275
G1Y-1.192
G0X.900
M1
(FLAT 3)
G0C90.
G0X.582
G1Y.996F18
G0X.472
G1Y-1.104F12
G0X.900
M1
(FLAT 4)
G0C270.
G0X.582
G1Y.996F18
G0X.472
G1Y-1.104F12
G0X.9
Z-.05T0
/B9(HIGH PRESSURE OFF)
M1
(.236 / 6 MM DRILL)
T0800
M58S3=2000
G0C0.
G98G19
G0X.85T08
Z.401
Y-.236
G1X-.6F10
G0X.850T0
M1
(.375 C-SINK 90/CHAMFER #1)
T0900
M58S3=500
G98G19
G0X.900T09
Z.401
Y-.236
G1X.174F6
G4U0.2
G0X.900T0
M1
(.157 ENDMILL /.2756 C-BORE# 1)
(ROUGH)
T0700
#510=.265
#511=.1575
#512=.314
#513=6
#514=[[#510-#511]/2]
M58S3=4000
/B8(HIGH PRESSURE ON)
G98G19
G0C0.
G0X.900T07
Z.401
Y-.236
X.5
G1G98X#512F#513
G3W#514K[#514/2]
K-#514
V[#514*2]W-#514K-#514
V-[#514*2]J-[#514/2]
(FINISH)
#500=.2776
#501=.1575
#502=.314
#503=10
#504=[[#500-#501]/2]
G1G98X#502F#503
G3W#504K[#504/2]
K-#504
K-#504
V[#504*2]W-#504K-#504
V-[#504*2]J-[#504/2]
/B8(HIGH PRESSURE OFF)
G0X.9T0
M1
(.375 C-SINK 90 DEG. CHAMFER #2)
(OFFSET # 19)
T0900
M58S3=500
G98G19
G0C180.
G0X.85T19
Z.401
Y.236
G1X.174F6
G4U.2
G0X.850T0
M1
(.157 ENDMILL/.2756 C-BORE #2)
(OFFSET # 17)
T0700
#510=.265
#511=.1575
#512=.314
#513=6
M58S3=4000
G98G19
G0X.900T17
Z.401
Y.236
X.5
G1G98X#512F#513
G3W#514K[#514/2]
K-#514
(FINISH)
#500=.2776
#501=.1575
#502=.314
#503=10
G1G98X#502F#503
G3W#504K[#504/2]
K-#504
K-#504
G0X.85T0
M1
(.375C-SINK 90 DEG./.059X45 DEG.)
T0900
M58S3=2000
G98G19
G0X.85T29
G0C-90.
Y-.7
X.450
Z.140
G1Y.7F10
X.38
Y-.7
G0X.85
G0Z-.05T0
M1
M5(STOP SPINDLE)
M18C0
M1
( MILLED FLATS)
T12
G98G19
M59S3=5000
(FLAT 1)
G0C0.
G0Y1.35
Z.370
X.551
G1Y-1.1F25.0
G0Y1.35
X.9
M1
(FLAT 2)
G0C180.
G1X.275
G1Y-1.28
G0X.900
M1
(FLAT 3)
G0C90.
G1X.472
G1Y1.125
G0X.900
M1
(FLAT 4)
G0C270.
G1X.472
G1Y-1.125
G0X.900
G50W0.59(CANCEL OFFSETS)
G99G40G18M60(CANCELMILL)
G0Z-.05T0
M1
(ODTURN DEBURR.004 TOOL NOSE RAD.)
T0200
G97M3S1=6000
G0Z-.05
X0T02
G1Z0F.003
X.1572,C.006F.0005
Z.165
X.78
G0X.85
G97G0Z-.05T0
M1
!L10
( CUTOFF)
N19
T0100
/B4
M87
M97
G97M24M3S1=3000S2=3000
G114.1H1D-2R0.0
G99G18
G0Z1.204
G650(SUPPORT ON)
!L20
!L30
/B4
G50W-0.625(LOAD OFFSETS)
/B1(HIGH PRESSURE ON)
G99
G0X.900Z.579T01
G1X-.02F.003
/B1(HIGH PRESSURE OFF)
G50W0.625(CANCEL OFFSETS)
G97
G113(CANCEL SPIN SYNC)
M86
M96
G600
M5
M25
G4U.5
M8
M8
/M98P8000
M9
M9
M7
G4U.5
G0X-.02Z0.525T0
M6
M56
M53
M118
G999
M118
M5
N999
M2
M99
$2
M118
(SAFE START CODES)
G99
G50Q2000S8000
G50Z0
(END SAFE START CODES)
G610
G600
T3000
G4U.5
G50Z0
M98H21(ABD-125375R)
G50Z0
M98H100(EJECT PART)
!L10
M16(SS OPEN)
M118
G650(SUPPORT ON)
M77(WAIT FOR SYNC)
G0Z-.05
G98G1Z.125F10.0
G4U.5
!L20
G99
M15(SS CLOSE)
!L30
G600
G50Z0
G999
M52
M98H21(ABD-125375 R)
M98H100(EJECT PART)
M53
N999
M2
M99
N21(ABD-125375R)
T3200
G44G97M24S2=6000
G50U0.114(LOAD TOOL OFFSET)
G99G18
/B4
G0Z-.05
X-.700T32
Z0.
G1X0.0F.001
/B4
G50U-0.114(CANCEL TOOL OFFSET)
G97G0Z-.05T0M25
M99
N100(EJECT PART)
M25(SS STOP)
M33
G0Z1.500
M16(SUB OPEN)
M10(KNOCK-OUT ADVANCE)
G4U2.0
/B4
G4U0.5
/B4
M11(KNOCK-OUT RETURN)
T3000
G50Z0
M119
M99
$0
A
#814=0000007500
#815=0000001000
#816=0000001000
#817=0007000000
#822=0000000030
#824=-000000200
#818=0000012820
#819=0000001000
#820=0000000000
#821=0000000520
#990=0000142000
#991=0000051000
#992=0000061000
#893=0000000000
#25119=0000012820
