Hello everybody
this is my new CNC project working on it with 3 other guys
The table is made from Steel I-Beam 8mm Thick
Machine Size: 190 x 320 x 35 cm
Working Size X,Y,Z : 150 x 260 x 20 cm
Spindle: 4.2KW, Water-Cooled, ER20 (tool size: 1/16", 3/32", 1/8", 3/16", 7/32", 1/4",
5/16", 11/32", 3/8", 13/32", 7/16", 1/2" )
Water Pump With Tank
Spindle Speed: 0-24000rpm with VFD, Delta Inverter VFD055B23A
Z axis driver: Stepper Motor Nema 34, 122kg-cm Holding Torque 6.2A
Z Motion : BallScrew 25mm , Square Guide Rail 25mm HIWIN
X axis driver: Stepper Motor Nema 34, 214kg-cm Holding Torque 6.5A
Z Motion :Rack&Pinon with Gear ,Square Guide Rail 25mm HIWIN
X axis driver: Double Stepper Motor Nema 34, 214kg-cm Holding Torque 6.5A
Z Motion : Double Rack&Pinon with Gear , Square Guide Rail 25mm HIWIN
and here is some pictures
would like to hear your ideas , is it good to have my Z Axies made from Steel or Aluminium , will keep update topic
one more thing , how good is this Delta VFD-B Series nverter for 4.5KW Spindle
Thank you
