586,055 active members*
4,352 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Help repairing Suregrave Wizzard DT machine
    Mar 2014
    Red face Help repairing Suregrave Wizzard DT machine
    I am a teacher of technology and my department has had to replace a failed Suregrave Wizzard DT with a Roland Modela. However, the machine is in perfect condition but it is the controller that has failed. I believe this is the Hi Drive version and uses a remote control handset.
    it has been tested and it seems the logic board (power board) has failed with no obvious way to get a replacement anymore. The rest of the machine is in great condition so I wanted to salvage it somehow.
    i believe that you can use other controllers with the actuall milling part of the machine and wondered how this works.
    any suggestions? There are 5 serial connectors that link the machine itself with the hi drive controller in the base if that helps.
    Re: Help repairing Suregrave Wizzard DT machine
    Hi Splinters are you still looking for someone who can repair these types of machines? if so let me know and i will send you my details. Cheers Phil
  1. Wanted HI Drive logic board for Suregrave/Dahlgren engraver
    By splinters69 in forum Want To Buy...Need help!
    Last Post: 03-01-2014, 05:33 PM
  2. Dahlgren Wizzard DT software
    By Black pig in forum Engraving Machines
    Last Post: 11-11-2013, 10:10 PM
  3. dahlgren/suregrave wizard 2000st help
    By seadanzig in forum Engraving Machines
    Last Post: 02-12-2013, 08:26 PM
  4. Old Dahlgren Wizzard XL
    By Popeye in forum Engraving Machines
    Last Post: 04-19-2011, 04:42 PM
  5. Need Mach 2/3 Wizzard Quick!
    By elalto in forum Employment Opportunity
    Last Post: 07-19-2005, 05:44 PM
