586,035 active members*
3,908 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Added custom horizontal spindle on indexing C axis to old Digital Tool machine
    Aug 2004
    421
    In continuation of this thread: max-rpm-miter-gears-designing-angle-head It is finally working.
    It is controlled by an AB Micrologix 1200 plc. Mach3 outputs modal values via Modbus to the plc for rotation position of the head. The plc generates step & direction and drives the stepper with a Gecko G213V. After it arrives at position, an internal locking pin is thrown to guarantee accuracy and holding force.
    See the video, this part took 3 setups previously!
    If you try to make everything idiot proof, someone will just breed a better idiot!
    Video is set to private, so we can't see it.
    Aug 2004
    421
    oops try again
  1. 1 DEGREE INDEXING ON HORIZONTAL MACHINING CENTRES
    By DYNAMIC1 in forum Uncategorised MetalWorking Machines
    Last Post: 01-12-2013, 01:40 PM
  2. Digital Tool Meta Machine Router
    By 3dcncin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2011, 10:16 AM
  3. 4 Axis Indexing On Horizontal (B-Axis)
    By Markced in forum Surfcam
    Last Post: 02-01-2011, 08:25 PM
