586,094 active members*
4,116 visitors online*
    Feb 2014
    58
    Exclamation Mach3 is moving in the opposite direction
    I am newbie in the CNC field and I made my first cut yesterday. Although it was successful I had to go opposite direction of what I was planning too, that rewind my material as it was cut in a random place. I used a DXF file on CamBam to generate the tool path, then the gcode and Mach3to run it. When I am on Mach3, I go left with the left arrow Mach3 goes right and vise versa. Is this normal or I have a problem in the hardware or there is a setting in Mach3 that I missed? I am using Sherline CNC Mill
    When you click the left arrow, which way does the table move?
    You can reverse the direction of an axis in Config > Homing/Limits, check the "Reverse" column.
    Feb 2014
    58
    Thanks for your reply. The bed goes left when i press the left arrow. However, the axis itself on the screen goes right
    Feb 2014
    58
    Cool
    Found the problem. I didn't configure the Post processor in CamBam to Mach3. It was using Default. Now it is working fine.
  1. Y axis gets itself stuck moving in one direction
    By Smokey911 in forum Tormach Personal CNC Mill
    Last Post: 07-02-2014, 07:26 PM
  2. my cnc machine not moving in Z direction
    By durga prasad in forum Open Source CNC Machine Designs
    Last Post: 04-09-2013, 06:51 AM
  3. Mach3 DRO moving... but not the motor...
    By DarkStarMedia in forum Charter Oak Automation Support Forum
    Last Post: 08-31-2012, 03:03 AM
  4. Mach3 not moving motors
    By jasper371 in forum Mach Mill
    Last Post: 06-15-2009, 10:32 PM
  5. A3977/Mach3 Direction changes randomly
    By kiltjim in forum Open Source Controller Boards
    Last Post: 12-09-2007, 03:04 AM
