586,111 active members*
3,225 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > Dense Mesh Models
Results 1 to 7 of 7
    Mar 2011
    59
    Dense Mesh Models
    Hello,
    I'm looking for some advice regarding efficiencies when computing toolpaths for dense meshes.
    I have some models containing no NURBS, just dense meshes derived from grayscale images. Also known as height maps. The toolpath calculations are taking FOREVER!
    Any advice?
    Thanks.
    Apr 2004
    5737
    Can you decimate the meshes to lighten them up? Here's a tutorial on using Meshlab for that: Decimating Sculpts with MeshLab | Blender Cookie
    Andrew Werby
    Website
    Mar 2011
    59
    Quote Originally Posted by awerby View Post
    Hello and thanks for the reply.
    I understand. I have worked with these meshes previously for purposes of 3D printing. I use the "Mesh Reduction" command in Rhino on those with great success.
    However I am now attempting to create Lithophanes on my CNC router. I generate the beautiful photo mesh using Rhino Emboss. These meshes have photo detail and need to stay "somewhat" dense. See example below. Vectric makes an app called "Photo Carve". I've watched their demo and see their tool paths generated in a few seconds. 3D Lithophanes from photographs
    I don't want to buy more software and really believe that RhinoCAM can do this. Do we know for sure that it's the mesh density that is causing the slow computing?
    Thank You,
    Bernie
    Attachment 227096
    Apr 2004
    5737
    Quote Originally Posted by ssw View Post
    Thank You,
    Bernie
    Attachment 227096
    That would be my guess. What happens when you run Mesh Reduction on these files?
    Andrew Werby
    Website
    Mar 2011
    59
    Hi Andrew,
    My mesh reduction tests were inconclusive, because the tool path calculations never completed. I had to cancel them before they finished. I let one go for almost 2 HOURS before I killed it.
    I have made some progress though. I'm finding that it's not the number of triangles that causes the problems. It's how tight they fit in a given area. This is defined as the "resolution". I should have known that! For example, 1 million polys in a 2 cm x 2 cm area has issues, but 1 million polys in a 20 inch x 20 inch area works okay.
    So, I think I'm on the right track.
    Thanks for the help.
    -- Bernie
    Apr 2004
    5737
    Hi Andrew,
    [I was thinking you'd reduce the mesh before trying to do the toolpaths. If that's what you did, I'd say the test was conclusive, but negative.]
    [That seems odd to me; I'd look for another explanation. After all, the program can use mm or inches, and has no internal check to see which is being used for a given operation, so 20 inches would be the same as 20 mm as far as it's concerned. Have you looked at your Rhino tolerances? Maybe they're set too high.]
    -- Bernie
    [Let us know how it goes. Have you asked Mecsoft's tech support about this? ]
    Andrew Werby
    Website
  1. A new tool to fill gaps in triangle mesh models
    By aiem in forum 3D Printing / Scanning Software and Hardware
    Last Post: 03-11-2016, 03:30 PM
  2. Mesh cam Art
    By speedtwin69 in forum Uncategorised CAM Discussion
    Last Post: 10-06-2012, 05:00 PM
  3. Mesh cam Art
    By speedtwin69 in forum Benchtop Machines
  4. 1.750" punched 304 stainless mesh - 0.028" 8x8 mesh
    By taiden in forum North America RFQ's
    Last Post: 08-25-2012, 05:50 PM
  5. DXF Mesh to Solid
    By automizer in forum Uncategorised CAM Discussion
    Last Post: 10-17-2007, 03:21 AM
