I have a COMBI 3000 with FANUC 210i-T control. The controller has a key in front from where you can choose MDI mode or EDIT mode. The EDIT mode is controller by a pc card that runs Win95.
I had a problem with the pc card. After a lot of research i managed to fix it (changed the ram module on top) and finally the machine is starting. I have an error 910 which is SRAM error. Sounds normal since i removed the SRAM card and i guess i lost all parameters. I have a printout with all parameters and also an old backup , but the problem is that i can't enter MDI mode. I turn the key and nothing happens. Tried to turn the key in emergency mode but still nothing.
Any clues?
