Re: Will upgrading my video card improve the toolpath window frame rate?
Your best option is to turn off the toolpath display when running large g-code files.
Abso-freaking-lutely. I run large files all the time. Mostly intensive 3D stuff. A couple hundred thousand lines of code are common. Several hundred thousand lines of code are not uncommon, and I have cut a couple jobs with over a million lines of code`. There is no way those can be done with the tool path display tuned on. I can predict a crash or a bad cut with nearly 100% certainty if I try. Instead I look at the actual job, and the history file to keep track of where I am in a job. I even have little CCCTV cameras inside the enclosure to help keep an eye on things.
Bob La Londe
http://www.YumaBassMan.com
