We are an engineering design company located in Westlake Village, CA and have an immediate opening for someone with excellent CNC programming ability, Solidworks and CNC machine shop skills.
Responsibilities:
Produces machined parts by programming, setting up, and operating a computer CNC machine; maintaining quality and safety standards; keeping records; maintaining equipment and supplies. Developing and designing of fixtures (using 4 axis machine tools), as well as applying good problem solving skills in order to assist/troubleshoot the production department in their day to day activities. You must possess strong programming, CAD/CAM and machine shop skills with a minimum 3 years of experience. Haas familiarity is required.
Requirement:
- AS degree is a plus but not required
- Pass in house exam.
- Minimum 3 years of machining experience with CNC lathes and milling machines.
- Good understanding of CNC panel and ability to detect and correct program errors.
- Ability to work with conventional Mills.
- Capable of working from blueprints, operation sheets, set-up sheets, and/or verbal instructions.
- Able to grind all standard tools such as tool bits and drills.
- Must be capable of using special measuring equipment like gauges calipers and the setting up and operation of tool preparation machines.
- Ability to work with minimum supervision, work with chief engineer to accomplish the projects.
- Ability to assist and train other operators when required.
- Good communication skills, must speak, read and write English.
- CNC Setup Experience is a must.
- CNC programming experience, M and G Code is a must.
Working hours : Fulltime with benefits.
Please send all emails regarding this position to [email protected]
