586,628 active members*
2,590 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Waylube pump upgrade
    Apr 2006
    43
    An older Fadal with a mechanical(motor driven) waylube pump.
    The motor seems to turn(very slowly as designed, but the gears don't.
    Does any know of a replacement pump or upgrade for this design pump. thanks.
    Aug 2003
    812
    You can call the factory or Devco with the part number and model number and get a replacement. The pump should have a tag on it somewhere with the numbers.
