586,080 active members*
3,715 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Cannot "Select Geometry" in V24 (specifically Engrave) - The geometry is points
    Mar 2006
    168
    Is there a work around for this?
    I'm trying to select a series of points to center drill (also tried engrave). At first it was crashing, now it's at least continuing to run, but geometry isn't selecting.
    It will however let me select lines (just not these points).
    Apr 2009
    3376
    Quote Originally Posted by 777funk View Post
    Can we look at file ?
    May 2013
    701
    Maybe check to make sure mask is checked All Mask
    The Green check mark is turned on.
    Apr 2009
    3376
    Also you don't engrave points.
  1. "The sketch has no countor geometry"
    By Eric MFG in forum Solidworks
    Last Post: 03-30-2022, 05:54 PM
  2. BobCad V24 "Select Geometry" problem
    By chuckmole in forum BobCad-Cam
    Last Post: 03-06-2014, 04:17 AM
  3. Replies: 9
    Last Post: 08-16-2013, 09:28 PM
  4. Setting "Z" tool coordinate in geometry offset
    By Jim Beyer in forum Mori Seiki lathes
    Last Post: 09-07-2012, 12:34 PM
  5. Can't select geometry?
    By phoodieman in forum Mastercam
    Last Post: 02-08-2010, 01:52 PM
