586,075 active members*
4,364 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Fixed gantry 500mmx500mm (4mm domex frame) build
    Mar 2014
    4
    Hi
    I am attempting my first Cnc router build and make my first rookie mistake right away.
    I designed and plasma cut the frame from 4mm domex steel plate and this is where i made my first mistake.
    In hindsight i should have laser cut them ,the piercings for alignment slots i made are 20mm x 4 mm and when plasma cutter pierced the steel it made about 5mm hole so the slots are actually oval not rectangular as 'n expected.I had to hand grind all the slots to make them slot together.
    Please comment on design so far and point out possible other hiccups I may encounter.
    Attachment 227292Attachment 227294Attachment 227296
    Mar 2014
    4
    Would drilling a grid of holes into the spoil board and plugging with dells work for clamping work piece ?
    The frame weighs about 40 kg is this good or bad for a router i know mills weigh a couple of tons ?
  1. Fixed Gantry CNC build log
    By shoot in forum DIY CNC Router Table Machines
    Last Post: 09-13-2019, 10:22 PM
  2. New DYI Fixed Gantry Router Build
    By DonFrambach in forum DIY CNC Router Table Machines
    Last Post: 07-06-2015, 12:45 PM
  3. Fixed Gantry - First Build
    By Schweeb in forum DIY CNC Router Table Machines
    Last Post: 04-01-2012, 10:49 PM
  4. Fixed gantry build-newbie tuesday
    By ahtopahtel in forum DIY CNC Router Table Machines
    Last Post: 01-17-2011, 12:38 PM
  5. Moving table fixed gantry build
    By judleroy in forum DIY CNC Router Table Machines
    Last Post: 12-15-2010, 05:11 AM
