586,693 active members*
2,751 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Windows 7 64bit - Mach3 - ugh, one more thing to deal with now....
Results 1 to 7 of 7
    Oct 2007
    446
    Question Windows 7 64bit - Mach3 - ugh, one more thing to deal with now....
    Hello,
    I am just getting into CNC with a small machine that I am hoping to have up and running in a few months. I bought a separate PC system to run all of my CAM(recommend 64bit system) and CONTROL SOFTWARE with a parallel port to (gecko G540) only to just now realize that i have windows 7(64 bit) running on it. Apparently 64bit will not work with Mach3.
    So after some searching i see that people mention a separate motion controller(usb) to overcome this which is unfortuate...seems like just another thing to complicate the whole process.
    I've come across this
    USB MOTION CONTROLLER for Mach3, UC100 | Automation Technology Inc
    Just wondering what you recommend to work around this??
    If Mach 4 is coming out shortly (this summer?) does it have 64 bit OS support to run off parallel port???
    If so, then I would just wait until the new version is out.
    Please advise,
    Jeff
    No, Mach4 will not support the parallel port on a 64bit OS. 64 bit versions of Windows will not allow it.
    The UC100 seems to be very popular, and is probably the cheapest option to use Mach3 on a 64bit PC. There are similarly priced Chinese motion controllers on Ebay as well. For basic needs, the Pokeys may also be an option, and it adds lots of I/O.
    Oct 2007
    446
    just curious how friendly these are to use? I can just plug this directly into my gecko g540 from the pc/usb?
    -trying to wrap my head around all of this stuff....from actually getting the machine in working order...to finding a cam package(decided on now)...to control software and now figuring out how to get all of it working together....
    Oct 2007
    446
    So even if the new version of Mach comes out I would still need an external motion controller in order to hook up to the gecko driver....
    Quote Originally Posted by airbrush View Post
    Yes, if you're using a 64 bit OS.
    And yes, you just plug the G540 into the motion controller instead of a parallel port. They work very similarly.
    Oct 2007
    446
    ok...one more thing to add to list....
    Jan 2006
    115
    Mach 4 has been coming soon for several years.
  1. Camsoft and windows 7 64bit
    By miran70 in forum CamSoft Products
    Last Post: 04-21-2013, 02:09 AM
  2. 64bit windows to 32bit WinXP problem?
    By rockson31 in forum 3D Printer / 3D Scanner Discussion
    Last Post: 01-20-2012, 08:19 PM
  3. MasterCam X5 on windows 7 - 64bit
    By pearldiver in forum Mastercam
    Last Post: 07-27-2011, 03:21 AM
  4. Granite Drive with Windows 7 64Bit
    By speedydumpster in forum CNC Machine Related Electronics
    Last Post: 07-06-2011, 11:47 PM
  5. Camworks 2007 on a 64bit Windows
    By Andreas0815 in forum CamWorks
    Last Post: 09-28-2007, 01:50 AM
