586,102 active members*
3,180 visitors online*
IndustryArena Forum > Additive Manufacturing / 3D Printers and 3D Scanners > Electronics > I'm confused about capacitor for a blower motor
Results 1 to 5 of 5
    Nov 2009
    79
    I bought a small blower a while back & never was able to figure out what capacitor to get for it.
    web search returned too technical info for my level
    Ametek Rotron propimax 3BL part no 041037 series 763ZH
    115 volt ac
    60 hz
    1 phase
    .13 amp
    3450 rpm
    PH. SEQ
    Cap 0.5 (with no u or F) so am I right in assuming it is .5F?
    has a small wiring diagram [see photo (fixed type capacitor ?)]
    I buy from digikey so if someone can point me to a solution, part no greatly appreciated.
    Also which wire connects to black? yel or red?
    Thanks in advance
    Dec 2003
    24221
    If it was 5F you wouldn't be able to get it into your shop!!
    It is most likely 0.5µf
    Make sure you get AC motor run rated cap, a oil filled paper is typical type.
    You can also get them at a local rewind shop.
    The cap goes across RD and BE, whatever they are.
    Al.
    Albert E.
    Nov 2009
    79
    okay, so I go to digikey and search for 'capacitor' too many choices and none say oil filled paper
    so I search for 'oil filled paper' - nothing
    then I search for 'AC motor run' - returns 'film capacitor' as one choice
    filter for 0.5uF
    and I get 4 capacitors, all motor run type, but they are rated:
    440-700 volt AC and are 2.160" L x 1.310" W x 2.250" H
    costing $12-20
    really?
    the motor is less than 1.25" in diameter & less than 1.75" long
    the blower is 3.75" overall diameter
    the wires are only 20-24 gauge
    Does this blower really need a capacitor that is larger than the motor?
    And does it matter which way the capacitor is connected to the red & blue wires?
    Dec 2003
    24221
    For a small motor You may get away with metalized polypropylene, for cheaper.
    Polarity does not matter.
    R46KI347000N0M Kemet | 399-5463-ND | DigiKey
    Al.
    Albert E.
    Nov 2009
    79
    thanks
  1. wiring a 220 volt capacitor start motor
    By cambridgecnc in forum CNC Machine Related Electronics
    Last Post: 03-08-2014, 05:33 AM
  2. 5HP 3PH motor + 2000CFM blower.
    By diyengineer in forum Maintenance DIY Discussion
    Last Post: 04-26-2011, 10:38 AM
  3. Purpose of Capacitor connect with Spindle Motor?
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 11-13-2009, 05:05 PM
  4. PSC motor capacitor trouble
    By ericaustin in forum CNC Machine Related Electronics
    Last Post: 07-25-2008, 01:24 AM
  5. Non-polarized start motor capacitor in DC
    By jc40 in forum CNC Machine Related Electronics
    Last Post: 11-17-2007, 05:37 PM
