586,106 active members*
3,165 visitors online*
Results 1 to 7 of 7
    Mar 2014
    7
    fagor 8055 tc
    I need cabel diagram for FAGOR 8055 with eprom and with 9 pin on the cabinet
    it´s will not work with windnc .. and parameter is the control
    can´t not find not find anything on the internet .. only windnc.
    my connector on cabinet has pin out of 9 pin female connector 5-6-9 loopet pin 1-2-3-8
    Mar 2014
    7
    Re: fagor 8055 tc
    update pin 5-6-9 loop pin 1- 2- 3 -7 on cnc
    Apr 2014
    5
    Re: fagor 8055 tc
    The 8055t man is free to download Fagorautomation.com it should have all the RS232 info there. CNCNew could help too. Socal.
    fagor 8040
    where I can faund mashine parameter for FAGOR 8040TC(or 8055)?
    8040 and 8055 are the same. Here is the file that you are looking for:
    man_8055_inst.pdf
    You can find it in the following link of FAMA Technology website.
    http://famatechnology.com/cms/wp-con..._8055_inst.pdf
    Mar 2014
    7
    Re: fagor 8055 tc
    cabinet 2 -3 -7 8055 old eprom
    Apr 2015
    170
    Re: fagor 8055 tc
    The 8055 eprom model uses a different rs232 connection to the later 8055i. Pin 2 goes to pin 2 and pin 3 goes to pin 3. They are usually reversed. The 8055i has extra parameters but is otherwise identical. It does work well with Wind DNC. Dave
  1. Connect PC to Fagor 8055
    By jbrookes in forum Fagor Automation
    Last Post: 03-05-2015, 10:19 PM
  2. Fagor 8055 G 54??
    By clayman in forum Uncategorised MetalWorking Machines
    Last Post: 08-19-2013, 06:29 PM
  3. fagor 8055
    By cncsed in forum Fagor Automation
    Last Post: 09-06-2011, 02:21 AM
  4. Fagor 8055 and edgecam
    By DUDS in forum Fagor Automation
    Last Post: 12-13-2010, 08:39 PM
