My y and z axis are off. What are your values for step per?
Almost ready to make some chips! Enclosure should be done tomorrow!
-Keith
-Keith
OK set it to 10160 and it is still way off. How do you check the steppers themselves?
-Keith
Keith,
How are the switches set on your stepper drivers?
When you say "way off" - how far? 2X? 10X? If you move 1" on Mach3, how far does it really move?
Regards,
Ray L.
On my Torus, the Y axis was about 50% off. I think it was a switch setting, but never messed with that.
I just used a dial gauge and got it set right to that.
Both X and Z were perfect though. That is why I think it was a switch setting.
Lee
Here's the manual for the stepper driver:
http://leadshine.com/UploadFile/Down/MA860m.pdf
Are you sure you've got your units set correctly? Is motion perhaps off by a factor of 25.4?
Regards,
Ray L.
I was thinking the same thing. Check that you got the units in Mach 3 in Inches, not mm's
Nate
Fine Line Automation
Home - Fine Line Automation
www.finelineautomation.com
