586,121 active members*
3,643 visitors online*
    Nov 2013
    8
    voltage how much ?
    I have 3 23HS9430 Frame Size: NEMA23 Step Angle: 1.8 degree Voltage: 6.3VDC current: 3 A/phase Resistance:
    2.1Ohm/phase Inductance: 9mH/phase Holding torque: 30N.cm 425oz-in Rotor inertia: 810 g-cm2
    Detent torque: 0.89 kg-cm Number of wire leads: 4 Weight: 1.55KG How much voltage do I need or the max I can use?
    I have a 36 volt power supply but the motor seem slow and under powered my table is 4 foot X 3 foot .can anyone tell me the max voltage I can run this motor at or any option . thank you
    Nov 2013
    8
    no help for this one ok Ill move on
    For maximum performance from those motors, you'd want about 96 Volts.
    Nov 2013
    8
    OK thank you 96v I have stepping motor drive using DC 36V will the drivers stand 96 v or do I need new drivers ? I an so green at this
    Jan 2007
    146
    If the power supply is matched to the driver, then I suspect the driver can't support much more voltage. You kept the driver type a secret.
  1. Help..Stuck at relay ext dc voltage missing but dc voltage OK ?
    By Dirky in forum Bridgeport / Hardinge Mills
    Last Post: 05-14-2021, 06:39 PM
  2. High voltage power supply, low voltage perihperals
    By feechl in forum CNC Machine Related Electronics
    Last Post: 01-07-2014, 02:12 AM
  3. Precix 9100 Controller - VI voltage issue Voltage range only 6.5 to 10Volts
    By wdysf150 in forum Controller & Computer Solutions
    Last Post: 08-15-2013, 08:24 PM
  4. DualDC - HV bus over voltage or under voltage fault
    By legendboy in forum CNC Machine Related Electronics
    Last Post: 01-25-2012, 11:25 PM
  5. what voltage?
    By haroldj in forum Stepper Motors / Drives
    Last Post: 03-04-2008, 01:10 PM
