Re: Servo driven tailstock programming
hy
M56 : tailstock moves near part, then clamps
M55 : tailstock moves away from part
those codes work togheter with positions defined into the tailstock table, that can store up tp 10 different sets; also, if you are intersted, is possible to define those positions by g-code
when you use the tailstock, is needed to define turret index positions, and aproach/depart movements, in such a way, that it won't hit the tailstock
if you wish to setup fast, i can guide you remotely, answer all your questions; you will be up to it in no time / kindly
