586,108 active members*
3,084 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Tool coolant controlled by solenoid on Haas stopped working
    Mar 2014
    Hi there,
    We have a Haas in our shop whereby the tool coolant is controlled by solenoid at the back of the machine and it has to be turned on manually instead of using G Code (refer to picture 3). The tool coolant was working fine this morning until it stopped working suddenly where there is no air coming out at all. If you look at picture 1, if we would to take the master air hose out and connect it to the tool coolant hose, there is no problem for the air to come out at all.
    We are suspecting that it could be a broken solenoid (refer to picture 1) that causing that issue or there might be some other reason for this to happen. Any advice would be helpful.
    Thank you very much.
    Attachment 227854
    Attachment 227856
    Attachment 227858
    Jul 2005
    12177
    You turn the valve on by hand. What controls the solenoid valve?
    Feb 2010
    1184
    Quote Originally Posted by [email protected] View Post
    Hi there,
    Attachment 227854
    Attachment 227856
    Attachment 227858
    It's a pretty basic system.
    If you have power to the solenoid but no air, then you have a bad solenoid.
    If you don't have power to the solenoid, then you have issue with whatever you have powering it and/or a bad solenoid.
  1. Replies: 3
    Last Post: 05-09-2013, 02:28 PM
  2. My flood coolant stopped working
    By islandracing in forum HURCO
    Last Post: 01-24-2011, 04:06 AM
  3. G203V Stopped working
    By LazyMan in forum Gecko Drives
    Last Post: 09-10-2009, 03:45 AM
  4. SX3 Stopped Working
    By mikemill in forum Syil Products
    Last Post: 01-09-2009, 04:54 PM
  5. Gecko 202 stopped working
    By jimglass in forum Gecko Drives
    Last Post: 04-17-2006, 07:01 PM
