586,094 active members*
3,772 visitors online*
Results 1 to 9 of 9
    May 2006
    86
    Tormach 1100 Drawbar Wrench Size
    Howdy,
    Do y'all know what sized wrench the Tormach 1100 drawbar takes? I need to checkout the pawn shops for a ratcheting box wrench for it. They usually run about $2 at a good pawn shop
    Thank you,
    kr
    http://www.parmarng.org/freeidaho/default.html
    http://xlforum.net/vbportal/forums/showthread.php?t=999415
    Oct 2006
    137
    Not sure what size it is, but mine has a square head. i just use a metric adjustable spanner for it.
    Will
    Nov 2012
    130
    Quote Originally Posted by wbleeker View Post
    Will
    Metric adjustable?
    Pretty sure my adjustables don't skip over the metric sizes....
    May 2006
    86
    Will
    Thank you Will,
    Any chance you have a caliper handy?
    Thanks again,
    kr
    Feb 2009
    2143
    12-point sockets/box wrenches work fine on square heads...
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Jan 2012
    789
    My series 1 is 13mm.
    Apr 2013
    99
    13 mil square the ceapo that come with it works fine, open end wrench is fine
    May 2006
    86
    Excellent. By my calculations, 13mm square turns out to be 15.9mm hex wrench, so 16mm (12 pt). It is also exactly 5/8" hex wrench (12 pt).
    The ratcheting box end wrench is the neatest thing since ratchet wrenches. I will stop by the pawn shop tomorrow and pick up a 5/8" ratcheting end wrench for a couple bucks.
    Thank you very much,
    kr
    Nov 2013
    402
    I need to make a 13 mm socket, brass hammer combo for my drawbar.
    Add that to my 'to-do' list.
  1. Problem with my PCNC 1100 Power Drawbar
    By cobrakai in forum Tormach Personal CNC Mill
    Last Post: 09-03-2013, 07:16 AM
  2. New Tormach 1100 series 3 vs. Old Tormach 1100 series 1 to purchase
    By inventor1227 in forum Tormach Personal CNC Mill
    Last Post: 03-21-2012, 09:55 PM
  3. Tormach 770 and 1100 drawbar lengths?
    By ImagineRobots in forum Tormach Personal CNC Mill
    Last Post: 03-08-2012, 09:17 AM
  4. Replies: 11
    Last Post: 01-22-2011, 12:38 AM
  5. anyone know what size spanner wrench?
    By jderou in forum Bridgeport / Hardinge Mills
    Last Post: 06-03-2005, 02:01 PM
