586,104 active members*
3,331 visitors online*
    Oct 2005
    17
    Speed adjustment on a V2XT
    Does anybody know how to configure the speed parameter for a BMDC control.
    Nov 2004
    3028
    If you have a spindle drive such as on an EZPATH or a VMC, you adjust parameter 72 so the output from the BMDC to the drive results in a actual spindle speed (verified by an encoder) to match your commanded speed. This also assumes that the encoder count and sample period are also set correctly.
    On a V2XT all of the above is irrelevant. The V2XT uses a prox switch in the gear shift to tell it if it is in high or low gear. Then it uses a voltage devider circuit which is a glorified variable resistor (volume control) as a approximate spindle speed feedback circuit. The variable resistor is mounted in place of the spindle speed dial.
    George
    Oct 2005
    17
    Spindle Command Gain
    What is this command used for and How is it set up?
    ;Spindle Command Gain
    ;Scale factor for Spindle speed commands - formula for Spindle Gain is:
    ;SpindleGain = (MaxDacCnt/2)x(MaxDesiredVoltage/10)x(MaxRPM/4096).
    00000023757 ; 071
