586,100 active members*
2,906 visitors online*
IndustryArena Forum > CAM Software > Mastercam > cant get this custom tool profile to work.
Results 1 to 5 of 5
    Sep 2008
    37
    Hey Guys
    I need to get this custom tool profile added into my library but it fails everytime.
    Ive checked the chain it looks good.
    ive tried with/without centre line
    ive tried making the centre line same length as my profile and longer
    ive re imported my dxf multiple times tried it as a DWG
    ive tried just exporting just selected lines to make sure theres no random line parts
    attached is a mcx5 file of my profile
    thanks for your time in advance.
    There is always another option.
    Oct 2006
    104
    The link is no good. Post the file to the site so we can look at it.
    Oct 2006
    104
    Can you save it as a Mcam file or dxf
    Dec 2008
    3109
    There is certain criteria that must be met before it works
    If "custom tool", it must be drawn full size.. Usually, the drawing cannot be used for a different size tool.
    If using as a "standard" shape ( flatmill etc), See below
    - lines & arcs only.....no splines
    - no overlapping entities, all ends must be trimmed
    - drawn in TOP view in the X+Y+ quadrant, & placed on the Z zero plane
    - centre line can be omitted,
    - try to place all entities on the same level
    - the tool shape is NOT used to calculate toolpaths---it is for graphical purposes only ( backplot & verify )
    - Mastercam uses the Tool OD (or Base dia with side angle) & Corner radius, for toolpath calcs.
    a DXF of certain tools have the habit of replacing splines with very small lines ( often, these do not trim exactly ), You could fit arcs to the shape to replace the tiny lines. It also improves the graphic screen refresh rate, backplot & verify speeds
    the other rule
    - a full scale drawing of the tool is to be scaled so that the tool radius is equal to 1 unit ( it gets multiplied by the tool diameter ) -- this is typically a single tool drawing that can be used for various sizes.
    Sep 2008
    37
    thank you superman,
    that's exactly what i needed.
  1. Do Custom UCS' work for CAM?
    By mcphill in forum BobCad-Cam
    Last Post: 06-10-2011, 08:23 AM
  2. Custom machining work
    By mothman in forum RFQ (Request for Quote)
    Last Post: 04-20-2011, 08:11 AM
  3. Replies: 6
    Last Post: 06-21-2010, 09:33 AM
  4. Work Hold down, How is best for Profile Cut?
    By dneisler in forum MetalWork Discussion
    Last Post: 12-07-2005, 02:50 AM
  5. Anyone want to do some custom Milling work??
    By mrbaseball in forum Commercial CNC Wood Routers
    Last Post: 10-21-2005, 11:33 PM
