586,108 active members*
3,080 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Y axis tramming question
    Mar 2011
    480
    Hi All,
    I found a thread of Ray's on making your own tramming tool which I did (Thanks Ray). I think I did everything right, and the x-axis seems good /repeatable. Adjusting X is obviously easy with the head bolts, but how do I adjust the Y ?. I've seen some threads about shims under the base etc, but would like a "reality check" before I do anything with the Y. The X was out about .010 over 10 inches (my hole to hole distance on the indicators). Y looks about the same.
    Thanks in advance.
    -Matt
    Feb 2006
    7063
    Matt,
    Tramming Y requires loosening the bolts holding the column to the base, and slipping in shims.
    Regards,
    Ray L.
    Mar 2011
    480
    Got it. Thanks.
    Jun 2008
    1082
    In the diagrams of the Torus Pro it looks like the bottom piece of the column has screws coming from both the bottom and the top. If that's the case, should we loosen and shim the top part of the column?
    My Y seems to be very close to trammed, so I thankfully haven't had to mess with it yet.
    Mar 2011
    480
    After further testing, I was wrong on the Y. It is only .0005 out. So I ran my new Shars 2.5" face mill across a 2"x6"x5" block of 6061 and it looks very good. I have to try really hard to "feel" any transition in the step over in the facing passes. Very happy with the result.
  1. New Taig 2019CR-ER - tramming/setup question
    By LaserImage in forum Taig Mills / Lathes
    Last Post: 12-14-2016, 05:19 PM
  2. Z axis inbuilt tramming design help
    By Momentz in forum Mechanical Calculations/Engineering Design
    Last Post: 07-06-2013, 11:12 AM
  3. Tramming help
    By Momentz in forum DIY CNC Router Table Machines
    Last Post: 06-14-2013, 05:16 PM
  4. Head Tramming question(s)
    By mxtras in forum Bridgeport / Hardinge Mills
    Last Post: 05-04-2006, 07:45 PM
  5. Tramming question
    By ignatz in forum Benchtop Machines
    Last Post: 02-22-2006, 02:00 AM
