586,395 active members*
2,907 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > TL-1 Recording / Saving Conversational Programs
    May 2005
    94
    I can work my way though a part by programming it feature by feature using the conversational method. (is it called VQC on the lathes?). Every section gets written into MDI and overwrites previous operation. How can I copy each section out and string it all together into a repeatable program?
    Eg. I write the face program, it get's put and run in MDI. Next write the od turning program. It goes into MDI and overwrites facing. Etc Etc.
    Thank you
    Jul 2005
    12177
    The only way I know is to convert each section in MDI into its own program: Type a program number (O00001, O00002, O00003 etc) at the beginning of the first line and press ALTER. This will give you a series of programs you can then stitch together using the Clipboard.
    Aug 2012
    27
    Re: TL-1 Recording / Saving Conversational Programs
    I believe F4 outputs the code from IPS to a program while cyclestart just dumps it into MDI and runs from there. That is, if you're using the Intuitive Programming System...I've never used VQC.
    Nov 2006
    490
    Doesn't the VQC menu give you the option of "output to current program"? (option 3 is output to MDI if I recall)
    Otherwise Geoff's suggestion would take care of it just fine.
  1. Saving/Loading programs on a 6M?
    By QUALMACH1 in forum Fanuc
    Last Post: 07-07-2015, 05:42 AM
  2. ProtoTrak SMX on a DPM2 not saving programs
    By Spiderman in forum Uncategorised MetalWorking Machines
    Last Post: 11-28-2011, 11:40 PM
  3. Problem Saving Programs to VF2
    By dingo0722 in forum Haas Mills
    Last Post: 12-28-2010, 07:52 PM
  4. help saving programs on 93 daewoo lathe to pc
    By machineman66 in forum Uncategorised MetalWorking Machines
    Last Post: 06-03-2010, 12:20 AM
  5. Help downloading conversational programs
    By kmc5266 in forum HURCO
    Last Post: 06-09-2007, 04:07 PM
