When the precision is shown is DeskProto, does this mean that this is the limits of the precision? For example, a centering ring that is milled from 0.25” plywood, that is 2.916” inch on the outside and 1.636” on the inside. If the precision is greater than 0.001” does this mean that it will not be able to achieve the cut? Or does the precision mean something else? Also, it appears that the diameter of the cutter impacts precision as well.
Could someone explain this to me?
Greg
