Hi, i am back again with some results.
Attachment 293408
At the attached photo you can see various cuts of circles (50 mm dia). Using the 3d tabs i have only one defection located left and right of the tab which is also the starting point of the process.
No matter the size of the tabs the defections exists.
It comes to single line when i use lead in - lead out method, this is logical.
The results are fine when i use smooth ramp or circular lead method.
So the problem was solved but i still dont understand why everytime the bit moves down to z-axis collides with the object.
some thoughts:
For sure there is not problem of table's vibration because the movement at z axis has no resistance at this point. But i also hear squeak while bit going down.
For sure my router does not spining conical because the diameter of the circles are constant when measuring them.
The post processor seems to be fine.
May be, there is vibrations of the material when the bit spindles with 17000 RPM inside it ? Its that possible ?
Do you have this issue when you cut with your machines ?
Regards
Chris
