I'm a long ways from being the expert on Haas yet, I just had my first look around
If the tool seats a wee bit deeper after the grind, it is going to affect the drawbar pull pressure a little bit, but not nearly as bad as omitting a washer or two, because one missing washer is probably going to allow the drawbar to drop (relax) 3/32" or so. After a grind procedure which only removes a couple of thousandths, there is really nothing to adjust with the drawbar spring stack if it was in good shape to begin with. With a force measuring instrument, a person should be able to adjust the washer stack to the nearest whole washer (obviously) to get into the correct pressure range.
When I put the spindle back in the machine, my main concern with the umbrella tool changer was that the tool flange slide straight onto the fingers in the carousel, which it seemed to be so close to perfect (without adjusting it) that I did not fool with it.
The Tool release piston astride the drawbar, I did have to adjust by a single.010 shim.
That is all on a Haas, I don't know how the Fadal might be different.
