Hi all,
I have a second hand Chinese lasercutter (JSM 6540H) that I've not been able to get working. The current issue is that it doesn't seem to want to move along the Y axis.
When I push the "Test" button with a loaded file, it makes a juddering vibrating noise, and then moves only along the X axis. Normally it should quickly move along the outline of the image to be engraved/cut.
No idea what I should be checking. The only thing I've done is replace the limit switches, because it was easy.
Any advice of what I could be looking at gratefully accepted.
Thanks in advance.
