586,077 active members*
3,711 visitors online*
IndustryArena Forum > CAM Software > SheetCam > new drawings way too small
    Jul 2004
    51
    Opening saved jobs are working OK but when a new drawing is opened, it's rendered way too small to be processed.
    Nov 2004
    141
    You are probably trying to open an inch drawing as metric. When you open the drawing an options box pops up. Make sure you set the drawing units to Inches.
    Les
    Jul 2004
    51
    Les,
    Thanks for the reply, I discovered it this morning. When setting the units to inches in the setup wizard, I assumed it would automatically set the drawing units accordingly.
    al
    Nov 2004
    141
    One of the problems with dxf files is that they are unitless. Some cad packages always save in metric even if you draw in inches, some always save in inches and some depend on your drawing. As there is no standardisation I have to give you the option to select which mode the drawing uses.
    Les
