586,060 active members*
4,468 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V25 Advanced Rough Arcs
    Oct 2008
    9
    Is there any way to limit the size of the arcs created in the advanced rough feature? I am getting arcs with R values over 15400.00 which causes an alarm in my Haas VF-2 control. The arc fit tolerance is .0005. I can reduce the arc fit tolerance to make the arcs smaller but would prefer not to reduce the tolerance when it is not needed. I looked through the post processor but could not find any way to limit the arc size there. Any ideas? Thanks.
    Mark
    Dec 2011
    295
    Some were I saw use arcs button, I would say NO. It would post G01.
    Dec 2005
    121
    In the preferences menu and part then goto system and set the spline facet tighter . Try and see if works
  1. V25 PRO Advanced Rough/Adaptive Rough
    By RAF. in forum BobCad-Cam
    Last Post: 10-09-2013, 03:51 PM
  2. V25 question re: Advanced Rough usage
    By tlharris in forum BobCad-Cam
    Last Post: 06-04-2013, 03:21 PM
  3. advanced rough
    By bobcad guy in forum BobCad-Cam
    Last Post: 05-11-2013, 06:58 PM
  4. advanced rough strikes again
    Last Post: 05-07-2013, 03:54 PM
  5. Advanced rough
    By Koblenzer in forum BobCad-Cam
    Last Post: 09-30-2011, 09:41 PM
