586,035 active members*
3,620 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Arduino Sherline Rotary Table controller
Page 2 of 5 1234
Results 21 to 40 of 86
  1. #21
    Jan 2014
    57
    Re: Arduino Sherline Rotary Table controller
    Quote Originally Posted by bpratl View Post
    Thanks I will give that a try. Bob
    I tried ver # 1.0.5 and I still get the same errors and I can not find what is causing it. Bob
  2. #22
    Jan 2014
    57
    Compiling errors found and corrected. I found four print "Reset" commands that had a missing quote at the end, once added the java stack overflow error was eliminated . I also had a compile copy error, that was trying to print a undefined variable " DegreesetKey()". I had to comment it out in order to get the sketch to compile without errors. I'm not sure of the variables function. I am now able to upload the sketch and finish the project.
  3. #23
    Sep 2009
    1856
    try this just unzip it it should be fine
  4. #24
    Jan 2014
    57
    Dan, thanks for the download, it compiled without a hitch. Bob
  5. #25
    Jan 2014
    57
    Are there any good updated Arduino sketches, for the indexer, using touch screen LCD or LCD2004 & keypad? Bob
  6. #26
    Sep 2009
    1856
    you can do it if you wont:devious:
    it would not be that hard its just mapping of the buttons that need done or where on screen the buttons are
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
  7. #27
    Jan 2014
    57
    Thanks, I will give that a try. Bob
  8. #28
    Jan 2014
    57
    I made some changes to the sketch and added a few functions that help in the initial setup and operation.
    Attached Files Attached Files
  9. #29
    Jun 2007
    16
    I'm having some problems with this, it is compiling ok. When I turn it on the stepper instantly will run for about 2 seconds and then the lcd will flash for a little while and sometimes I will get 0 0 near the bottom of the screen. Any idea what could be wrong?
  10. #30
    Jan 2014
    57
    I'm not sure why it's not working. The only problem I had was in using the correct libraries and make sure that pin 12 is STEP and 13 is set for DIR and that the keypad is using pins 4 through 11.
    PM me your email and will send you the libraries that I used. Bob
  11. #31
    Jun 2007
    16
    PM sent
  12. #32
    Jun 2007
    16
    Ok, Have got it working now, thanks for the files. I had LiquidCrystal_I2C.o missing for some reason.
  13. #33
    Jan 2014
    57
    Quote Originally Posted by Com_VC View Post
    `Glad to hear that you got it working, I had the same problem with a missing file. Bob
  14. #34
    Nov 2011
    8
    hello , i ran across your program it is just what i am looking for , just downloaded thank you. the program doesn't run newer version of arduino problem with liquid crystal_i2c lcd(0x27,20,40); line "invalid conversion from 'int' to 't_backlighPol'[-fpermissive] im new to the programming stuff have no clue about it thanks
  15. #35
    Sep 2009
    1856
    you need LiquidCrystal_I2C librarie post a pick of the error it should say what is missing
    [SIGPIC][/SIGPIC]
  16. #36
    Jan 2014
    57
    Quote Originally Posted by fiddle561 View Post
    If you can't find the correct libraries, PM me your email and I will forward them to you. Bob
  17. #37
    Nov 2011
    8
  18. #38
    Sep 2009
    1856
    [SIGPIC][/SIGPIC]
  19. #39
    Nov 2011
    8
    thanks i will try it
  20. #40
    Sep 2009
    1856
    it is a problem with the new version of arduino I cant get it working ever some words are wrong hit the same problem its the starting of the screen (int screen)
    [SIGPIC][/SIGPIC]
Page 2 of 5 1234
  1. G1049 Rotary Table Versus Sherline set up
    By rkernell in forum Benchtop Machines
    Last Post: 08-21-2010, 03:31 AM
  2. Sherline rotary table threading
    By MechanoMan in forum Benchtop Machines
    Last Post: 07-08-2009, 11:23 PM
  3. Adapter for Sherline rotary table
    By diamondback21 in forum Taig Mills / Lathes
    Last Post: 04-13-2009, 11:26 AM
  4. Sherline CNC rotary table adaptation
    By uptoolateman in forum Benchtop Machines
    Last Post: 02-06-2009, 09:48 PM
  5. SHERLINE rotary table
    By ACME in forum Benchtop Machines
    Last Post: 11-17-2004, 05:15 AM
