586,108 active members*
3,288 visitors online*
Thread: Mach 3
Results 1 to 9 of 9
    Oct 2011
    69
    Mach 3
    here goes
    I setup a job so center is in the middle of the wood. when I start and run the job it starts out ok for the 1st pass but when it gest to the 2nd pass it has move's
    over to the right little by little on each pass Attachment 228822Attachment 228824 I am running mach 3 any help if I need to reinstall the program or just reconfigure my mach3 I just don't know how this happen it was working just fine a week before and I did nothing just turn on the computer. As you can see in the photo's that they both mover over to the right every time. My machine is a KL6090
    Jun 2008
    562
    Almost looks like a coupling or something is slipping in the drive train. I had that happen on my Z axis where I started getting random grooves. I tighten the coupling and all was fine. I don't think its software related.
    Mike
    Apr 2005
    1268
    Yup, that's a mechanical issue. Either a loose coupler of some sort or the stepper is stalling. Mach will not enter an offset by itself.
    Take a look at the mechanicals for loose screws or binding in the axis.
    Good Luck.
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Oct 2011
    69
    Thanks Mike 1948 it was a coupling it cracked now I need to find a new one for my NEMA 34 stepper motor 640 oz in
    Oct 2011
    69
    does anyone know where I can buy a coupler 10mm to 14mm CNC Motor Shaft Coupling Coupler
    Jun 2008
    562
    Oct 2011
    69
    thanks mike but I need a rigid Attachment 228854
    Jan 2014
    Socoolmart on eBay, saw some of those somewhere in his pile of couplings the other day
    Jan 2014
  1. Mach 3 + G540 + UC100 + WJ200 = Can't run spindle from Mach 3?
    By zer0fighter in forum Benchtop Machines
    Last Post: 09-08-2013, 10:54 PM
  2. little lost on G03 between Mach and PCNC 1100 Mach...
    By Spinnetti in forum Tormach Personal CNC Mill
    Last Post: 10-30-2012, 02:56 PM
  3. Replies: 3
    Last Post: 05-14-2010, 09:16 AM
  4. Servo Drive Card for Mach II / Mach III
    By umarcnc in forum Mach Mill
    Last Post: 02-21-2010, 09:37 AM
  5. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
