586,121 active members*
3,129 visitors online*
    Aug 2013
    6
    Knurling Trouble
    Im having trouble getting a clean knurl in 6061-T6 with a bump knurl. Typically I use a "Cut Knurl" for aluminum but, the parts I'm running have a tapered OD that I'm applying the knurl to. I'm using a taper knurl holder w/ a 3/8" x 3/4" 28tpi die. All my OD dimensions and plunge depth seem to be correct so, no double tracking. My knurls are coming out with fine chip residue between them, and I'm having to 2nd op these parts on a bench grinder with a wire wheel to clean them up. Part Dia. is approx .950", 450 RPM with a plunge feed rate of .006" per rev. I really need to correct this problem. The shop up the street, competition, has some of the best knurls I've seen and they aren't giving up any secrets.
    Jan 2007
    206
    Re: Knurling Trouble
    Check out Dorian Tool international in East Bernard Texas, knurling is one of their specialties
    Good Luck
    The Farmer,
  1. Knurling
    By dinnese in forum CNC Swiss Screw Machines
    Last Post: 02-07-2012, 06:25 AM
  2. Knurling
    By vbundy in forum MetalWork Discussion
    Last Post: 01-08-2010, 09:38 PM
  3. CNC Knurling
    By Gary4man in forum MetalWork Discussion
    Last Post: 11-20-2008, 02:43 AM
  4. Knurling with V9
    By DublJ in forum Mastercam
    Last Post: 01-05-2008, 03:31 AM
  5. knurling
    By SAWMAN in forum MetalWork Discussion
    Last Post: 03-17-2007, 03:50 AM
