Another question hopefully you can answer.
I use 3D bridges in my toolpaths to hold parts whilst cutting. If the 3D bridge is on a straight cut it works fine, however if the bridge is on a curve the movement becomes jerky etc..
Is there a setting in Mach that may eliminate this?...
Normal cutting of curves and circles are no problem, perfect.
Any help appreciated.
cheers
Frans
